#11
Re: BBC Tarantula manifold vs weiand tunnel ram ?
BBC Tunnel Ram with two 660's sound's cool and you only plan to drive it an occasional 20 minute cruise,YES COOL. I think you would drive it more if you like it too.
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Plowman</div><div class="ubbcode-body">BBC Tunnel Ram with two 660's sound's cool and you only plan to drive it an occasional 20 minute cruise,YES COOL. I think you would drive it more if you like it too. </div></div>
Plowman I'm going to end up driving it every chance I get once I lay into it lol... |
#13
A pair of 450's would be better for the street with a TR. A tarancula manifold has no low end torgue. Maybe with a big block you could make it work for the street. On a small block they are just terrible. That's why the torker manifolds came out so soon after the complaints they got about the taranculas.
#14
So you are thinking of going anything over 10:5:1 cruise. Mixing gas is a pain.
We recently did 14+-1 for the street. I have found that there is no "golden rule" for pump gas. That's just my finding.
I too like the "OLDe SCHOOL" or "PERIOD CORRECT" style stuff. It's alot harder to do with old, cheap out-dated stuff then the current stuff. You haven"t said what it's going in?? FYI I did a 396 (402)/375Hp L-78 OEM bottom end (11.5-1 TRW std bore), but added ARM bolts, 840 heads, Comp 660 roller cam, 1.73 roller off Ford Cleveland, Strip dom intake and Holley 800. 1969 Nova M-21 and 4.56 12 bolt. Heads were home-ported and car went 10.47 FIRST and only FULL 1/4 mile hit. This was in about 1996/97 time. So you should be EASY to hit your goal if Brandywine did the 990's. I think your going to be 9's if your using the TR. I'm putting together 4 motors like this. The above mentioned L-78 396, 427-390Hp, ZL-1 and ZLX. I have 3 tunnelrams and 9 intakes. ZLX is going to be set-up with at LEAST 12.5-1 comp and a Eddy TR2-X tunnelram, just not sure if it will be 4150 or 4500 carbs as I have one of each. Good luck, should be fun! my L-78 style 10.40 motor was when it was streeted. Shifting just over 8200 yippy!
'58 Apache pick up restomodding with twin turbo 522 '78 Z28 4sp being restored '78 Z28 32,000 survivor, Og Yellow paint, AC. '70 W30 convert TRIBUTE '70 CANADIAN Nova SS396 L78 Pro Street '69 CANADIAN Nova SS 396/350 hp '67 CANADIAN Nova SS 427 10 sec. driver '66 CANADIAN Nova SS Race Car '69 FIREBIRD Tubbed Racecar '61 CANADIAN Pontiac Bubble top 409+/4sp (SOLD) '31 ALL STEEL Chevy P.U. GONE (EX-WIFES NOW) |
#16
Just out of curiosity, what did the `69 Nova weigh?
#17
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: EZ Nova</div><div class="ubbcode-body">We recently did 14+-1 for the street. I have found that there is no "golden rule" for pump gas. That's just my finding.
I too like the "OLDe SCHOOL" or "PERIOD CORRECT" style stuff. It's alot harder to do with old, cheap out-dated stuff then the current stuff. You haven"t said what it's going in?? FYI I did a 396 (402)/375Hp L-78 OEM bottom end (11.5-1 TRW std bore), but added ARM bolts, 840 heads, Comp 660 roller cam, 1.73 roller off Ford Cleveland, Strip dom intake and Holley 800. 1969 Nova M-21 and 4.56 12 bolt. Heads were home-ported and car went 10.47 FIRST and only FULL 1/4 mile hit. This was in about 1996/97 time. So you should be EASY to hit your goal if Brandywine did the 990's. I think your going to be 9's if your using the TR. I'm putting together 4 motors like this. The above mentioned L-78 396, 427-390Hp, ZL-1 and ZLX. I have 3 tunnelrams and 9 intakes. ZLX is going to be set-up with at LEAST 12.5-1 comp and a Eddy TR2-X tunnelram, just not sure if it will be 4150 or 4500 carbs as I have one of each. Good luck, should be fun! my L-78 style 10.40 motor was when it was streeted. Shifting just over 8200 yippy! </div></div> It's going in a 69 camaro, that's why I asked about your grump lump! Hahaha. Yeah I think it should hit low 10's with out a problem. As for the race gas I've built a few race gas "street" cars and other than the price of the race gas I really don't mind. EZ NOVA your set ups sound badass! Any pics?? |
#18
Scott and Ken just tok that Yellow Deuce to 10.7 I think with a little 350, I trust you can run your number. Can't wait to see pics.
#19
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: pxtx</div><div class="ubbcode-body">Scott and Ken just tok that Yellow Deuce to 10.7 I think with a little 350, I trust you can run your number. Can't wait to see pics.
</div></div> This car went 10.70's? https://www.yenko.net/ubbthreads/ubbt...opics/597217/1 |
#20
No, that car is just started the transplant / freshen up.
THIS ONE WENT 10.75 |
