Old 09-18-2015, 07:03 PM
Default Re: 1969 X77 05C ZL2 Survivor pics
It takes a lot of work to replicate the controlled chaos of an assembly line... gun angles and speed make all the difference.
This shows where I scratched off the black and get the grey primer exposed, also the P T B stamps.
Old 09-18-2015, 07:59 PM
novadude novadude is offline
The sloppy factory firewall paint is funny. Very few would actually restore a car that way. Just like people fret over perfect panel gaps and perfect straight body panels. That type of perfection never existed when these cars were new.
Old 09-18-2015, 08:07 PM
camaromb camaromb is offline
On the blue car you can see the transition from firewall black to white over spray quite clearly on the passenger side firewall and on the firewall behind the distributor base (firewall black mostly below on tunnel and more white above on the flat firewall area) and below the wiper motor at the seam is mostly firewall black and more white overspray going upwards. The Fisher body grey I have seen is quite grey, kick panel areas, etc. The firewall black is most often absent in the areas behind the wiper motor, an area that typically rusts. I have an original '69 Camaro with a very crisp mask line for the firewall black, it goes beneath the wiper area, very little paint there.
Old 09-18-2015, 09:11 PM
m22mike's Avatar
m22mike m22mike is offline
Shauger is spot on, your looking at gray primer on the blue car.
Mike
Old 09-18-2015, 10:46 PM
DarrenX33's Avatar
That's a cool car.
1969 Z28
1972 Corvette
Old 09-19-2015, 02:35 PM
enio45 enio45 is online now
looks like my late fathom green car with all the white stripe overspray...very hard to duplicate!
Eddie M
Camaro-less
87 El Camino SS
Few Ferrari's
Old 09-20-2015, 01:46 AM
Mike,
I've never seen grey primer over the firewall black. I've seen the grey primer under the dash black and under the firewall black, I've never seen it used over the black paint in these areas. Ed's firewall looks the same, lots of white overspray over the firewall black, Thanks for the pics Ed.
Old 09-21-2015, 01:06 AM
m22mike's Avatar
Mark
Well aware of that, looking at the close up shot of the trim tag on the blue car, I see gray primer and a lack of blackout all together.
Mike
Old 09-21-2015, 01:56 AM
Steve Shauger's Avatar
Administrator
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: m22mike</div><div class="ubbcode-body">Mark
Mike</div></div>
We're seeing the same thing Mike. There is no blackout on the upper portion of the firewall that I can see just gray primer. There's not much paint covering the upper firewall, hence the rust...
I'm going by a small picture so it's hard to make a definitive statement. Could the blackout be covered by the white stripe overspray making it look gray...sure.
www.yenko.net
www.vintagecertification.com
Old 10-08-2015, 03:28 AM
Survivors, restored cars, &amp; other photos
