Old 03-15-2016, 09:00 PM
cook_dw's Avatar
cook_dw cook_dw is offline
Default Re: Vintage BBC headers
I do my own coatings using Cerakote Coatings.
Old 03-15-2016, 09:05 PM
How does the Cerakote hold up on headers?
John 10:30
Old 03-15-2016, 09:39 PM
cook_dw's Avatar
Holding strong to this point and its been over a year.
Old 03-15-2016, 11:59 PM
DW31S's Avatar
DW31S DW31S is offline
Tell us more Darrell.
Old 03-16-2016, 12:46 AM
cook_dw's Avatar
Here is the website. They dont have a ton of colors but if you go to their firearms website then they have more.. I have looked at several of those data sheets and it claims 1200 heat resistant but I do not have first hand experience with it. If someone wants to they can send me their part and pay to have it blasted or already have it done and cover the cost of the coating Ill do it for free for the next month or so and you let me keep whats left of the liquid. I only use air cure due to not having an oven for just this process but that could change. Just pm me if interested. You can also try for yourself just use a HPLV gun and I run roughly 20-30psi on the gun. Just practice. A lot. A 4oz tester sample will do quite a bit but I would get a pint if you want to do headers.
http://www.cerakotehightemp.com/
http://www.cerakoteguncoatings.com/finishes/
Ive also used their piston thermal coat and micro slick coating.
Old 03-16-2016, 12:32 PM
Nice work Darrell!
Old 03-16-2016, 04:58 PM
YENKO DEUCE REGISTRY's Avatar
Interesting....
Marlin
Old 03-17-2016, 10:09 AM
69L78's Avatar
69L78 69L78 is offline
When painting headers yourself, I learned many years ago the hard way. My first experience, I am sure many of you have had this happen, I would use VHT paint and after the first start-up, the paint would start to peel almost instantly. I learned this trick from a friend of mine, I use a hand torch and heat up the header from the inside and then apply the paint. I never had a problem after this.
Old 03-17-2016, 12:26 PM
m22mike's Avatar
m22mike m22mike is offline
Marlin
I used the cheap Hookers on my Malibu. Was not looking to spent stupid money for a set, and I hate shiny headers. Car has PS and they fit well.
I removed the black paint on them, gave the metal some tooth, etched with phosphoric acid and paint with VHT, so far so good.
Mike
Old 03-17-2016, 07:41 PM
Thanks all, especially for the suggestions in keeping the VHT on the headers. Benjamin and I will use one of these methods on these:
Marlin
