Old 03-16-2016, 02:26 PM
iluv69s iluv69s is offline
Default Re: 1970 Camaro Rear..
my orange 70Z had M-21 and 3.31 posi... I believe all original....
my silver 70Z car has original M-21 and rear coded for 3.73 posi... now 4.56's
Old 03-17-2016, 04:26 PM
COPO COPO is offline
<div class="ubbcode-block"><div class="ubbcode-header">Quote:</div><div class="ubbcode-body">=iluv69s]my orange 70Z had M-21 and 3.31 posi... I believe all original....</div></div>
Only 3.73 and 4.10 available in 70 Z-28's. 3.31 would have been either L-48 350 or the low HP 396. 3.55 was standard in L-78 and 4.10 was optional, but believe posi traction was mandatory option on L-78's and Z-28's.
Old 03-17-2016, 05:25 PM
WILMASBOYL78's Avatar
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: COPO</div><div class="ubbcode-body"><div class="ubbcode-block"><div class="ubbcode-header">Quote:</div><div class="ubbcode-body">=iluv69s]my orange 70Z had M-21 and 3.31 posi... I believe all original....</div></div>
Only 3.73 and 4.10 available in 70 Z-28's. 3.31 would have been either L-48 350 or the low HP 396. 3.55 was standard in L-78 and 4.10 was optional, but believe posi traction was mandatory option on L-78's and Z-28's. </div></div>
My first 70 L78 Nova was a non-posi 3.55 open rear. Based on window stickers I have for 70 L78 Novas...posi was an option. Not sure if this applies to Camaros but I would say it does. Perhaps others can add to this..it would be nice to see a 70 Camaro window sticker that shows the posi-traction option.
wilma
02 Berger 380hp #95
Lots of L78 Novas
Join National Nostalgic Nova!
70 Orange Cooler
69 Camaro
Old 03-17-2016, 05:10 PM
marxjunk marxjunk is offline
ive owned 2 real 69 Zs..both where 3.73 , neither had posi's or tachs...or cowl induction..all optional equip...and both where untouched original..
i have 4 friends with real z's..all had 3.73 non-posi...2 daytona yellow..2 hugger orange
these where all way back in the mid 80s...so..posi is optional and 3.73 is mandatory...more bread and butter z's out there than cool loaded up ones then..now..it seems all of them are loaded up...maybe options saved them..i duno..
cant comment on l-78s...never owned one....but knowing chevrolet...posi was optional in them too..but the gearing was mandatory..
just my experiences and opinions
Mark
Old 03-17-2016, 05:31 PM
Here's what Ive concluded after seeing Chevrolet/GM literature and contacting other
70' Camaro enthusiasts.
There was NO Camaro eng/trans combo that would have come with a 3:55 COW non posi rearend
ALL 70' L-34's came with 3:31 (Nothing Optional)
70 Z-28 was Std with 3:73 Optional 4:10 Posi was MANDATORY
70 L-78 was Std with 3:55 Optional 4:10 Posi was MANDATORY
70 L-48 4 spd Std was 3:31 Auto was 3:07
I am not listing the L-65 and 6 cyl ratios
Chuck Sharin
[email protected]
69 Camaro COPO &quot;recreation&quot;
Old 03-17-2016, 05:43 PM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: CamarosRus</div><div class="ubbcode-body">Here's what Ive concluded after seeing Chevrolet/GM literature and contacting other
I am not listing the L-65 and 6 cyl ratios </div></div>
OK...then how do we decide what car could have used this rear??
02 Berger 380hp #95
Lots of L78 Novas
70 Orange Cooler
69 Camaro
Old 03-17-2016, 05:59 PM
MosportGreen66's Avatar
Did the '70 Camaro have a 1969 'LM1 type' option where a car got a 4bbl 350, muncie 4 speed or Th400 and a 12 bolt?
Old 03-17-2016, 06:32 PM
ronzz572 ronzz572 is offline
Pontiac firebird list the COW axle code. I'm thinking a pontiac firebird formula or trans am. I am not sure if it was mandatory for positraction on the 70 trans am or formula. That is the only other car line it will fit.
1970 L78 camaro Cortez silver ralley sport under restoration
Old 03-17-2016, 08:51 PM
Mosport, I'm not familiar with a 70' Camaro Option LM-1
I can tell you my 70' SS R/S has the Std 350/4Bbl 300 HP
Muncie M-20 12 Bolt 3:31 (Not Posi) and F-41 Suspension
Dual Exhaust.
Chuck Sharin
[email protected]
Old 03-18-2016, 12:21 AM
Scott Kiehne who owns a 70 L-78 and past owner of a 70 L-34 wrote to me ..............
&quot;As a follow up on the COW 3:55 rear axle..
Attached is a picture of the AMA spec sheet for the 1970 Firebird. It shows the Firebird Formula &amp; T/A as using a 3:55 ratio in the open &amp; posi configuration. I also found a couple of Pontiac websites that show the Firebird using COW &amp; COX codes.&quot;
Chuck Sharin
[email protected]
