Old 06-12-2016, 11:23 PM
Alss's Avatar
Alss Alss is offline
Default Re: 70 W 30 rebuild
keeping the block..going 060... forged pistons comp ratio 10.5 or so, arp bolts and a shotpeen for the rods. polish crank, heads are in great condition..clean em up ..some new stainless valves and a three angle..new cam....assemble [img]<<GRAEMLIN_URL>>/smile.gif[/img]
1969 Beaumont 540 th400 3.70
1968 Camaro ragtop LSA ZL1
Old 06-12-2016, 11:45 PM
Ryan1969Chevelle's Avatar
Better read the PSMCDR rules, no rollers, and by memory cam lift has to be within 2% of stock grind:-)
Old 06-13-2016, 03:13 AM
Al.....build it the way you want to build it......we'll make our own race sanction.....we'll call it
&quot;BaDa Bing, BaDa Boom Racing&quot;.....Race what Ya Bring [img]<<GRAEMLIN_URL>>/[/img]
Old 06-13-2016, 10:25 AM
Alss's Avatar
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Ryan1969Chevelle</div><div class="ubbcode-body">Better read the PSMCDR rules, no rollers, and by memory cam lift has to be within 2% of stock grind:-) </div></div>
Houston, we may have a problem...WILL NOT use a flat tappet cam!..no way I'm spending good $$ and putting in a cam that may or may not survive..will be mild..and close to stock, but def a hyd roller. [img]<<GRAEMLIN_URL>>/smile.gif[/img]
Old 06-13-2016, 12:00 PM
Exactly [img]<<GRAEMLIN_URL>>/biggthumpup.gif[/img]
Old 06-13-2016, 04:05 PM
Stefano Stefano is offline
Dick Miller racing has a modified timing chain cover, looks stock when installed as its a stock one cut in 1/2, just in case you want to make cam swaps easier.
Click to visit the Nickey Performance Facebook--&gt;
Old 06-13-2016, 04:42 PM
83hurstguy 83hurstguy is offline
The challenge of the roller cam in an Olds is the 5/16&quot; rocker arm bolts. There are two basic options... the first is drilling the expensive/rare heads for a 3/8&quot; or 7/16&quot; stud and adding guide plates. Option 2 is the Harland Sharp 5/16&quot; bolt-on mini-shaft rockers, which are around $450, and good to 350 lbs open spring pressure.
With roller rockers, you'll have to modify/remove the stock valve cover baffles or double up gaskets. Ram Air Restoration makes a 0.200&quot; thick hard rubber gasket that's a nice piece. The stud mount rockers may clear with a short poly lock, but the mini-shaft ones hit the baffles at max. valve lift... went through figuring that out on my old '83 the hard way.
No doubt a roller is the way to go, other than those pesky Pure Stock rules. I'm stuck with the flat tappet for mine.
'68 H/O W45
'70 Cuda
Old 06-13-2016, 04:51 PM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Stefano</div><div class="ubbcode-body">Dick Miller racing has a modified timing chain cover, looks stock when installed as its a stock one cut in 1/2, just in case you want to make cam swaps easier.
</div></div>
Works for small blocks?
As far as I have researched this should be true:-) I want one!!
Ryan
Old 06-13-2016, 04:53 PM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: 83hurstguy</div><div class="ubbcode-body">The challenge of the roller cam in an Olds is the 5/16&quot; rocker arm bolts. There are two basic options... the first is drilling the expensive/rare heads for a 3/8&quot; or 7/16&quot; stud and adding guide plates. Option 2 is the Harland Sharp 5/16&quot; bolt-on mini-shaft rockers, which are around $450, and good to 350 lbs open spring pressure.
No doubt a roller is the way to go, other than those pesky Pure Stock rules. I'm stuck with the flat tappet for mine. </div></div>
Luke is a wealth of Oldsmobile knowledge:-) (I think he looked over this car at MCACN before it sold to Albert....)
Ryan
Old 06-13-2016, 04:57 PM
All Olds timing covers are the same from '64-up, so it should work.
Thanks for the kind words, but I'm no guru. At the rate you're going, you'll have more Olds experience than me in another week or two. I did spend some time at MCACN sitting next to this Olds in the post car display.
'68 H/O W45
'70 Cuda
