Old 08-29-2016, 03:45 AM
MECTransAm's Avatar
MECTransAm MECTransAm is offline
Default Vintage Hurst Loc /Out
does anyone have the installation instructions for a vintage Hurst reverse Loc/Out...the style that mounts between the shifter body and mounting plate..
i have one and if i tighten the upper shifter mounting bolt tight..it will not allow you to move the lever up or down ..if i back it off a couple turns all works well...so what would keep this from backing out and loosening?...wondering what the trick is here...thank you
