Old 09-07-2017, 11:59 AM
Originally Posted by camaromb View Post
Never fill gas containers above the ground for the same reason,potential static electricity buildup.
To make sure I understand; when I take my gas containers for my lawnmower to be filled they should not be placed on the ground by the pump when being filled? Where should it be placed?
Old 09-07-2017, 02:04 PM
camaromb camaromb is offline
Filling a gas container "above the ground" as in the bed of a truck, in the back of a car etc.
That has always been my understanding, fill gas containers "on the ground".
Old 09-07-2017, 07:56 PM
mssl72's Avatar
mssl72 mssl72 is offline
Some of those truck bed-liners can build up static.
Mark
1966 L72, 4spd Caprice
1974 Z28, M40 Camaro
Old 09-07-2017, 09:36 PM
Jonesy's Avatar
Jonesy Jonesy is offline
I think I would have a better chance of a meteor hitting me than some of the things happening that are mentioned above.
No smoking. Got it. Makes sense.
Fill containers on ground, not in truck bed with bedliner. Okay fine got it.
Phone exploding?
Dont Get back in car when refueling??
Look here and see this was back in 2003 and its pretty much word for word with the original post. Thats 14 years ago.
http://articles.mcall.com/2003-04-09...-mobile-phones
The Following User Says Thank You to Jonesy For This Useful Post:
67BelAir427 (09-07-2017)
  #15
Old 09-08-2017, 01:41 AM
ZLP955's Avatar
ZLP955 ZLP955 is offline
Interesting stats. Here in Australia, you can't lock the trigger of the pump in the 'on' position, so it's impossible to walk away from it while filling. Also, use of cell phones is banned while at the service station; if the attendant sees anyone using a cell phone, they remotely shut down the pump so the fuel flow stops.
Tim in NSW, Australia
Old 09-08-2017, 11:47 AM
That makes sense; however around here you can go to most gas stations and the attendant is often times talking on his cellphone the entire time he's filling your tank (in NJ you can't pump your own gas).
Old 09-08-2017, 12:28 PM
John's Avatar
John John is online now
Old 09-08-2017, 05:12 PM
Originally Posted by John View Post
As I understood it; filling gas containers in the bed of a truck or the back of a car = do not do
Fill gas containers while they're placed on the ground near the pump = yes.
Old 09-10-2017, 04:31 PM
Kurt S Kurt S is offline
The cell phone story is a myth. The DOT and EPA both have refuted that, IIRC.
Yeah, like when is the last time a phone exploded in your hand. And even if it did, the vapor density is not high enough to support an explosion. If it was, then overheating catalysts would be a bigger issue.....
Kurt S - CRG
The Following 2 Users Say Thank You to Kurt S For This Useful Post:
67BelAir427 (09-10-2017), cook_dw (09-10-2017)
  #20
Old 09-10-2017, 04:35 PM
cook_dw's Avatar
cook_dw cook_dw is offline
Thank you..
