Old 12-08-2017, 02:38 PM
X66 714's Avatar
X66 714 X66 714 is offline
You would need to look at the engine serial number in front of the RH cyl head. If it has a "V" then the engine was built in Flint & no sticker. If it has a "T" in front of the serial number, then that is Tonawanda & it would have the sticker....Joe
RAII4speed (12-08-2017)
  #12
Old 12-08-2017, 02:55 PM
RAII4speed RAII4speed is offline
Thanks ... It is a V
I don't hate the rich, And I don't pitty the poor
Old 12-08-2017, 08:06 PM
mssl72's Avatar
mssl72 mssl72 is offline
Originally Posted by RAII4speed View Post
I believe my car was built in Flint.
Would it have had a sticker on the valve cover?
I don't believe that Flint had a sticker like that. If I remember correctly Tonawanda only built big blocks. Can anybody confirm that?
Mark
1966 L72, 4spd Caprice
1974 Z28, M40 Camaro
Old 12-08-2017, 08:31 PM
You car was built in Willow Run.
Old 12-08-2017, 08:45 PM
danachevroletfor1967 danachevroletfor1967 is offline
To the best of my knowledge concerning 1st gen Camaros Tonawanda built small blocks (except for Z28 302's) and all big blocks. Flint only built small blocks including all the Z28 302's. I owned in the past a 1967 RS that I bought from the original owner. It was assembled in Van Nuys. It had the L30 327 that was assembled in Tonawanda, and it had the Tonawanda decal on the valve cover. I hope this helps.
Old 12-09-2017, 01:27 AM
Going by what X66 replied ....."You would need to look at the engine serial number in front of the RH cyl head. If it has a "V" then the engine was built in Flint & no sticker. If it has a "T" in front of the serial number, then that is Tonawanda & it would have the sticker....Joe"
My car does have a V , Is Willow run the same as Flint?
TIA
Old 12-09-2017, 01:44 AM
No,Flint Mi. is where your engine was assembled & the engine plant,before being shipped to Willow Run Mi. where it was inserted into your Nova waiting at the car assembly plant.
RAII4speed (12-09-2017)
