Old 05-03-2018, 04:05 PM
L78steve L78steve is offline
I've never cut one of these pumps apart. There are the 2 little holes in the cast part above the crimp that I assume are there to allow the gas to leak out in the event of a diaphragm failure and to prevent the fuel from reaching the lube oil.
Old 05-14-2018, 12:05 AM
Turns out it was the fuel pump leaking oil from the gasket. Oil was leaking into the fastener area due to the correct fuel pump bolts from a popular supplier were a tad too long and bottoming in the blind tapped holes.
Replaced the gasket with some anaerobic sealer and removed a bit from the bolt length and all seems fine.
Old 05-14-2018, 12:42 AM
Well that is good news!
Old 05-14-2018, 02:56 AM
earntaz earntaz is offline
Maybe small block bolts? They are longer than the BB bolt because of the adapter plate used on the SBC ... TAZ
Old 05-14-2018, 02:47 PM
Do the small block bolts have the captive lock washer and 7/16 hex heads?
Old 05-14-2018, 07:19 PM
I've seen them both ways. But OEM bolts have 7/16" heads and do not have captured lock-washers that I can remember ... TAZ
