Old 11-21-2018, 01:57 PM
70 Forest Green Zee's Avatar
Originally Posted by KenMaisano View Post
FYI All of your pistons are in backwards. Im guessing including the Thrust side of the rods...
You are very observant Ken...this was the first time I ever tore an engine down and rebuilt one and when we reassembled we put the pistons in backwards....fortunately after we bolted one of the heads back on and tried to rotate the crank and the pistons were hitting the valves, we realized our mistake and took all the pistons out and rotated them all 180 degrees. Boy, you can't get anything past the knowledgeable people on this site :-)
1970Camaro Z28
Old 11-22-2018, 11:48 AM
ban617 ban617 is offline
Great looking cars , I would think the bore is 4.00”
Maybe your confused with the 396 in 70 was 4.030 bore if I’m not mistaken..
What are wrong with the original pistons ? If your going to replace them I would measure the bore for roundness before ordering pistons , so if it’s out of round it could be fixed & have the block machined for the new pistons..
The Following User Says Thank You to ban617 For This Useful Post:
madden (11-22-2018)
  #13
Old 11-23-2018, 03:48 AM
COPO COPO is offline
If bore is in good shape, a simple hone and new rings could be the ticket and you can re-use the original pistons. Any competent machine shop can point you in the right direction. I wouldn't purchase any parts until after tear down and inspection by the machine shop.
The Following 2 Users Say Thank You to COPO For This Useful Post:
madden (11-28-2018), YENKO DEUCE REGISTRY (11-27-2018)
  #14
Old 11-23-2018, 12:42 PM
X2 COPO. Good advice!
The Following User Says Thank You to Salvatore For This Useful Post:
madden (11-28-2018)
  #15
Old 11-26-2018, 01:30 PM
rszmjt rszmjt is offline
Factory LT1 pistons have a .100 dome hite and were forged pressed pin, 302 has .200 dome hite and were forged as well with floating pins.
As noted 302 pistons have a different pin hite location in piston due to only 3” stroke, LT1 has a 3.48 stroke crankshaft, rods are the same length at 5.7”
Original LT1 was a 4.00” bore as noted, it makes sense to measure your bores for wear and if needed bore to .030.
Aftermarket L2304 are available in .030 & .060 only, some company’s make a cast type LT1 piston in .020/.030/.040/.060
If your motor did not have forged pistons originally you should have it rebalanced as piston weights are very different between cast and forged.
I do have a set of std & .030 I’m thinking, pm me if interested.
Hope this helps.
Mike.
The Following User Says Thank You to rszmjt For This Useful Post:
madden (11-28-2018)
  #16
Old 11-26-2018, 02:12 PM
There was a Speed-pro (TRW forged) piston available at one time in 40 over:
https://www.summitracing.com/parts/slp-lw2304f40
It was a lightweight forging, hence the LW.
I looked for them but could never find any available.
Owned since 1978 - First Car
The Following User Says Thank You to BCreekDave For This Useful Post:
madden (11-28-2018)
  #17
Old 11-26-2018, 05:00 PM
novadude novadude is offline
I can't imagine any 48 yr old block having absolutely perfect 4.000" bores without taper, etc. If you really want to do it right, I would suggest going 0.030" over and using any aftermarket LT1-style piston.
I guess you could get away with stock pistons and standard bore if you have a really great block, only want to idle onto a show field, and don't mind loose piston-to-bore clearance. These cars were driven hard when new, and it's pretty likely that they will ALL have some bore wear.
Old 11-26-2018, 05:44 PM
Here's the PDF showing all the pistons from Speed Pro including the L2304F at .040. Not sure they still make them but they are still listed.
I ordered the .430 domes last year and had them milled down for 11:1 compression in my 302.
madden (11-28-2018)
  #19
Old 11-26-2018, 11:37 PM
I agree completly, I have also gotten away with coating the piston skirts to tighten up the bore clearance somewhat if a budget is a concern? The L2304 can be run up to .005 ( IMO ) without skirt clatter when cold, let’s face it lots of these collector cars don’t see a lot of mileage every year, especially if you live in climate that has snow for up to 6 months like we do, or have your stuff in indefinite storage , LOL like me.
FWIW - the new version of the L2304 with coated skirts is no where near as nice as the older versions, not only is the pin 18 grams heavier, they are usually all over the place on pin fit, I just used a set of .060 and they were anywhere from .0001 tenth to .0006 tenths clearance. Plus the domes are almost a cast type rough finish. They L2304 domes are .200 give or take, the current L2210 - 302 piston comes with a .430 dome and must be machined to around .200 ( depending on chamber cc and head gasket parameters ) to achieve the original 11 to 1 compression ratio.
Hope this helps.
madden (11-28-2018)
  #20
Old 11-28-2018, 06:56 PM
madden madden is offline
rszmjt
hi mike
i sent you a pm regarding the pistons
thx
chris
1970 citrus Yenko Nova
