Old 12-03-2018, 11:19 PM
duskblue duskblue is offline
I just sprayed mine with zolatone. Looks great and it is tuff as nails. takes a quart and a half to do a camaro size trunk . and you need a HVLP to spray it.
Old 12-04-2018, 01:44 PM
x33rs x33rs is offline
Originally Posted by MYSTERYCHEVELLE View Post
Zolatone
mike
That's what I use.
Old 12-04-2018, 04:27 PM
Isn't the final stage of the Zolatone process a Clear coat and is this step completed or skipped?
Old 12-04-2018, 04:32 PM
You can clear coat if you wish or skip it.
Old 12-04-2018, 04:40 PM
m22mike's Avatar
m22mike m22mike is offline
Originally Posted by x33rs View Post
That's what I use.
How about some close up shots of the Zolatone ?
Old 12-06-2018, 05:51 PM
Beauty of ZOLATONE is no clear coat. As noted. Hard as a rock. No flash rusting even if moisture was to get in. My Danube Blue 66 SS was finished in 2001 and still looks like it was done yesterday. Web site may have close up but if not., I can take one
Old 12-06-2018, 09:38 PM
SS427's Avatar
SS427 SS427 is offline
The reformulated Berlage product no longer needs to be cleared either.
Rick Nelson
Old 12-07-2018, 02:37 PM
AutumngoldL78 AutumngoldL78 is offline
I've heard of some using black epoxy primer and than spattering the aqua over the top.How do you make the paint gun spatter big tip,low pressure?
Old 12-07-2018, 03:13 PM
Billohio Billohio is offline
My Z has the epoxy primer with aqua spattered. The ppg code on aqua was 43816. Turned out nice. Hard to get a good picture in the trunk
Bill
