#11
![]() Quote:
I HAD a Mallory Hyfire CDI box installed at one time. I eliminated it because I was trying to do a process of elimination to locate my issue. So actually, the CDI box was supposed to be getting 12 volts but was really only getting 8 volts.....through the factory resistor wire. So when I was still having issues, I purchased the new Unilite distributor, I read that it needs a 1.6 ohm resistor.....which I installed. Technically, I didn’t need that as the factory wire was already at 8 volts.....but again, I didn’t know that. So when I bypassed the resistor wire and went directly from the battery to the coil....everything was in normal condition. I will be reinstalling the Mallory Hyfire CDI box which will need 12 volts. So I ordered a new engine wire harness from America Auto Wire that will have the correct 12 volts to the CDI box. If I need to lower the volts, I can reinstall the resistor directly to the coil. Kurt
![]() 1969 SS396 Post Sedan Delivered to Van-T Topeka KS MCACN Day2 Concourse Gold Award 1965 VW El Lobo Dune Buggy built in the mid 70’s for the Iowa Shriners 1968 Schwinn Orange Krate 1969 Schwinn Pea Picker 1968 Schwinn 5-Speed 1970 Schwinn 3-Speed Deluxe 1972 Schwinn 10-Speed Continental 1973 Schwinn 5-Speed Suburban All Original Paint Bikes |
#12
See, just as I had said.... I knew all along you would figure it out
![]() Dan
69 300 Deluxe Post Sedan Frost Green 69 SS396 300 Deluxe Post Sedan Lemans Blue SOLD 70 Buick Skylark Post Sedan Gulfstream Blue 70 Buick Skylark Post Sedan Burnished Saddle http://m.youtube.com/watch?v=PM3DE8qI2NY https://m.youtube.com/watch?v=Yn4xEmGypUw |
#13
![]() Quote:
Just to add, when you are starting the engine key in start position and starter turning the resistor wire in the harness is bypassed and the coil receives full12 volts. After you release the key to the run position (engine running) the resistor power wire applies the reduced voltage 8 ish volts. Basically you get a hotter spark on startup and once running reduced to preserve the point s
Steve Shauger The Supercar Registry www.yenko.net Vintage Certification™ , Providing Recognition to Unrestored Muscle Cars. Website: www.vintagecertification.com |
The Following 4 Users Say Thank You to Steve Shauger For This Useful Post: | ||
69 Post Sedan (06-06-2019), earntaz (06-06-2019), PeteLeathersac (06-06-2019), Tracker1 (06-06-2019) |
#15
![]() Quote:
You are technically correct, but it's easier to measure the voltage drop. Obviously the voltage drop represents a reduction in current. In simple terms voltage is pressure and current is flow. If you decrease the pressure(voltage), flow (current) is decreased. ![]()
