Old 10-21-2019, 06:21 PM
YENKO DEUCE REGISTRY's Avatar
The Yenko Deuce Novas also received them, specifically the round style that has a superceded part # 1565208 with a 1 : .833 ratio for the 4.10 gears.
Marlin
Old 10-22-2019, 02:48 AM
x33rs x33rs is offline
I have a rounded version with .6481 stamped on it. I pulled it from the same car I pulled a BX code 4.88 rear from.
I've never been able to accurately cross that gear reducer number to anything but it does work accurately with that rearend.
The Following User Says Thank You to x33rs For This Useful Post:
YENKO DEUCE REGISTRY (10-22-2019)
  #13
Old 11-19-2019, 10:34 PM
The round reducer with 1:.833 is #6477965
67 Z/28 Butternut Yellow
69 Z/28 Rally Green
69 Z11 Pace Car
2010 2SS RS Aqua Blue
68 Z/28 Lemans Blue
C7 Corvette
68 SS Lemans Blue
The Following User Says Thank You to luv2sixty9 For This Useful Post:
YENKO DEUCE REGISTRY (11-21-2019)
  #14
Old 11-20-2019, 02:13 PM
copo69's Avatar
copo69 copo69 is offline
Did the Copo's and Z/28's with 15 inch tires use a reducer with 4:10 gears?
Old 11-20-2019, 03:56 PM
On some cars too with 3:73's
Owned since 1978 - First Car
Old 11-20-2019, 07:25 PM
Jonesy's Avatar
Jonesy Jonesy is offline
Originally Posted by cdn454LS6 View Post
I found one guy selling a reducer
and claiming it's for LS6 410 rear
666F V8
.8241C
maybe mine is for 456 rear ?
My 1974 z/28 4 speed has that same reducer on it. Its definately the original reducer. Im sure I have 3.73 rear
Here are pics:
Old 11-21-2019, 04:24 AM
Kurt S Kurt S is offline
Not on Z's. Never seen a 69 Z with one (though they may be out there). Only on first gen Z's with 4.56 and 4.88 axle.
Most I've seen were in BB cars and most were 14" tires. It depended on which trans version they received - there were different speedo drive gears (shown in that chart).
I've seen 2 different adaptors used in 69 - auto vs manual - but there probably were others for the special order 4.56 and 4.88 axles.
Kurt S - CRG
Old 11-21-2019, 12:49 PM
x77-69z28's Avatar
My turbo 400 70 Z with 3.73’s has one.
Buddy
Old 11-21-2019, 01:49 PM
My 70 4 speed car has one also. But I have seen many other 70Z's without one.
What I never could understand is the chart I attached a link to. It shows cars with a wide ratio (M20) getting one but cars with a close ratio not getting one. What difference does the trans ratios make??? The internal speedo gears are driven by the output shaft so the gears in front of them make no difference. Not to mention that in 4th, all Muncies were 1:1 anyway. Am I missing something here?
Old 11-21-2019, 10:09 PM
Sorry, clarified that I was only talking 67-69.
Kurt S - CRG
