Old 12-11-2019, 05:16 PM
SS427's Avatar
SS427 SS427 is offline
If you rebuild your own (very simple I might add), instead of buying a rebuild kit, buy a complete similar rebuilt master cylinder. You can buy the rebuilt master for less money then the rebuild kit. At least that has been my experience.
Rick Nelson
Old 12-11-2019, 06:29 PM
HawkX66's Avatar
HawkX66 HawkX66 is offline
That's exactly what I did. And here I thought I was being uniquely crafty lol It was actually because I couldn't source a rebuild kit when I did it.
-Dave
Semper Fi!
69 Camaro SS396 L34 X66
Old 12-11-2019, 06:38 PM
njsteve njsteve is offline
Whitepost. Really fast service. I have sent several over the years. I fedex them there on a Monday morning and have always had them back before Friday. One time I had it back Wed afternoon!. They sleeve them.
Note: If you want the original finish left alone, like on a survivor car, make sure you tell them beforehand so they don't paint it.
Old 12-11-2019, 07:58 PM
ronzz572 ronzz572 is offline
Just a heads up. I checked in on mine and they are a little backed up 2 to 3 weeks.
1970 L78 camaro Cortez silver ralley sport under restoration
Old 12-12-2019, 12:56 AM
cheveslakr cheveslakr is online now
HA! that's a bit better than Karps. They took 4 months on mine. It takes a lot for me to rip on someone, but when a company tells you 3 times over 3 months that it'll be done that very week, we have an issue. I sent my last resleeve to LoneStar brakes and they performed as I expected. They'll get my next one.
Rebuilding a master is a simple gig, but you need to source the best seals you can. Dealing with 2 stroke bikes will teach you this in a hurry.
Old 12-12-2019, 01:31 AM
CSS1970396 CSS1970396 is offline
Hi i just sent today to White Post my GM Moraine Master Cylinder for 1974 Trans am for sleeve and rebuild they told me takes 3 to 4 weeks to returned done but give me the option to pay 25% more and returned in 3 days after received also they told me they painted in cast grey in my case is good because i plan to repainted in black like comes from factory and the cast grey base is good to prevent rust in the future. after receive i posted pics before and after thanks
Old 12-12-2019, 12:59 PM
Burd's Avatar
Burd Burd is offline
His is pitted Has to be sleeved.
I sent my og master out to be rebuilt. $35. Came back all Brad lasted It went to Pittsburgh.
It's only Orig once
waste all the rest.
1978 Y88
1995 Q45
Old 12-21-2019, 03:35 PM
Bernhard Bernhard is offline
I have never had any luck with rebuilt masters even when the cars were only ten years old.
They would work for a month to a year and then started to leak and bleed off pressure.
Since then I have always used new and never had an issue.
I would only trust a quality sleeved master cylinder bore I'm done with honed bore masters.
If one could locate a core from a dry climate area then maybe it might work.
69 442 post bench 3 pedal
Old 12-21-2019, 09:44 PM
Burd's Avatar
he got it back the other day, there was a small charge to expedite the rebuild, it’s painted and ready to go on the SD. They even had the correct cap for 74, and it was plated factory Correct also.
It's only Orig once
waste all the rest.
1978 Y88
1995 Q45
Old 12-22-2019, 07:45 PM
Nice.
What do they charge for a re-sleeved master
The Following User Says Thank You to Bernhard For This Useful Post:
luzl78 (01-10-2020)
