Old 06-06-2020, 02:45 AM
TimG TimG is offline
Scott, the tank sticker would certainly clarify the sidepipe option.
The Following 2 Users Say Thank You to TimG For This Useful Post:
olredalert (06-06-2020), purple panther (06-06-2020)
  #12
Old 06-07-2020, 02:13 AM
scott s scott s is offline
I looked at the tank sticker its very dark and u can see stuff but not everything.
Old 06-07-2020, 02:06 PM
earntaz earntaz is offline
Originally Posted by scott s View Post
i think the pipes were added but are GM.
Check the panel below the back bumpers and see if it is original or glassed over ...
Old 06-07-2020, 02:30 PM
----One of the best ways of telling weather a Corvette came with sidepipes is to check the area directly in front of the rear wheel in the wheel well. The tab at the bottom has a half round slice taken out of it. Find a car that did have sidepipes from the factory and you will see what I'm referring to. That cut is almost never cut correctly by guys adding sidepipes.....Bill S
Old 06-07-2020, 04:53 PM
ssl78 ssl78 is offline
On a side pipe car the frame along the side pipes have notches in it and there is no rubber around the lower bolt in panel by the front frame
69 RS SS L78 conv
69 RS SS ZL1
69 L78 Chevelle conv
69 L78 Nova
69 L34 Nova
67 SS Chevelle
73 Trans Am
Old 06-07-2020, 04:57 PM
bobm67 bobm67 is offline
You can look for treads in the holes were they would fastened the ground straps to the transmission cross member. Also look for staple holes were the weatherstrip would have been fastened on the front fender lower rear mud shield. If it has the treads or the holes it didn't leave the factory with side pipes.
