Old 01-07-2020, 03:14 PM
Originally Posted by jl8z28 View Post
The purple cleaner turns the parts a white i wouldn't use that
----Also beware of prolonged use of purple cleaner as I have read reports that mention cancer and purple cleaner in the same sentence......Bill S
chris slawski (01-07-2020)
  #12
Old 01-21-2020, 09:03 PM
RSSSfan RSSSfan is offline
have had pretty good luck with Simple Green. Doesn't harm finishes, typically.
The Following User Says Thank You to RSSSfan For This Useful Post:
chris slawski (01-21-2020)
  #13
Old 01-25-2020, 07:20 PM
Originally Posted by chris slawski View Post
question with the OXY clean do the crystals dissolve enough not to clog up the sprayer?
I did get a small steamer like the one suggested
Big thanks for the warning of the purple stuff! Makes me glad I procrastinate
It will dissolve in HOT water...
chris slawski (01-26-2020)
  #14
Old 02-11-2020, 07:48 PM
ScottG's Avatar
ScottG ScottG is offline
I have had 2 Unrestored Buick National show winners. I cut down Simple Green to 30 percent . Spray it all down and get a stiff plastic brush . Move all the grease areas around with the brush. It might take 4 or 12 tries to get it good enough to be accepted as clean. Never ,, ever use that purple stuff. It bleaches aluminum and polished metals in seconds. You can pressure wash anything that does not have a decal or ink stamps. I just use hot water and let it dry.. Shoot the dry stuff with WD 40 out of a sprayer from the gallon meatal can . The WD 40 will also take off grease that you missed with the S G . It is not hard to do but it is very time consuming.. Have fun!!
1971 Boss 351 , 17,000 miles .. 1971 Buick GS455 .. 2003 SVT Cobra .. 1971 GTO .. 1969 Camaro Fathom Green .. 1969 Camaro Hugger Orange .. 1970 Buick GS455 .. 1970 BUICK GS350 .. 1998 SVT Cobra 1900 miles;. 1973 STAGE 1 GS . 1971 Mach 1 351C 4 speed , first car. 1970 Mach 1 428 SCJ . 1970 SS 350 Camaro . 1971 442 ... 1968 Buick GS400 . 2015 Lexus IS 350 F Sport 2021 Badlands Bronco Sport
The Following User Says Thank You to ScottG For This Useful Post:
chris slawski (02-23-2020)
