#11
But if it isn't the original block to the car its not really worth that kind of money in my opinion.
#12
yes that would be nice to find the car it belongs to if it is still alive ??
#13
Partial VIN will be down on the rough casting area by oil filter.
1969 Camaro RS/SS Azure Turquoise 1969 Camaro Z/28 Azure Turquoise 1984 Camaro z/28 L69 HO 5 speed 1984 Camaro z/28 zz4 conversion 1987 Monte Carlo SS original owner |
#14
You sure it's not a Ford? I see a little Ford Blue paint!
#15
looks like N684512 THE N&6 are very light but the 84512 is clear
#16
It's good that you can read most of the vin. Most times, you can't read the vin down by the oil filter. I heard that some blocks weren't stamped with a vin, if this is true??
#17
the guy that stamped must have been right handed !
#18
You sure about that second number being an 8? That would make this engine a bit too early for that VIN. Is it a 5 or 6?? Got pics??
#19
Seems a lot of blocks the N is not as clear, the fonts probably wore a lot from repeated use at the Norwood plant.
#20
I’ve seen a few blocks with no vin, last one was a 02 car
