Old 01-29-2020, 07:56 PM
Maybe it allows you to load the clutch a little while staged. Then it's not quite as hard of a hit when you let it go. A Line Lock would do the same thing, but this may have come out before the Line Lock.
Old 01-29-2020, 08:20 PM
----There you go. I was trying to figure out how this held only the front brakes. Every drag car is different as are we drivers, but, for instance, Red Alert didn't like the trans brake, or maybe that was me (dunno). Line lock was only for the burn. Once staged I just left-footed the brake, brought the RPM's up to around 25/2600 and matted it (5000 stall). Just me, but that produced the best 60 ft's and ET's......Bill S
Old 01-29-2020, 08:28 PM
Ryan1969Chevelle's Avatar
I want one!!! I don’t care what it does I like it!!
Ryan W31
Old 01-29-2020, 08:36 PM
I agree it has no value in drag racing, it could be useful on hills for street driving.
Really at the end of the day it is sort of like tow bar tabs. No one really using them they just look cool.
Old 01-30-2020, 10:51 AM
Keith Seymore's Avatar
'63 LeMans Convertible
'63 Grand Prix
olredalert (01-30-2020)
  #16
Old 01-30-2020, 11:12 AM
Originally Posted by Keith Seymore View Post
Sweet burn!!!
Ryan W31
Old 01-30-2020, 12:48 PM
ZAPPER68 ZAPPER68 is offline
Yenko Premier Member
Thumbs up
What's the process for launching a car with this device? Or does it just help to get staged properly? How does it help take the slack out of the driveline?
Does it toggle overcenter, and hold the brake? Or does the driver hold the lever to apply the brake?
The reason I ask: in my stick shift car, once the car is "staged" the foot brake is no longer needed. The car sort of settles into the slicks (wrinklewalls) and does not move.
Set the launch rpm, sidestep the clutch when you see the last yellow, and away you go!
K
I believe race brakes were used before line locks came on the scene. As mentioned in my case, with a 4 speed the brake is particularly useful at traffic lights where I live in the mountains...it works exceptionally well and I used it all the time.
I never used the brake at the track because I had a line lock for that exercise. However, without a line lock it would be useful to 'take out the slack' easily by clutch/race brake coordination...thereby possibly preventing a hard launch (& broken parts) clutch cars are notorious for. As we all know, sidestepping the clutch is brutal on the drivetrain which is something we're all guilty of at one time or another :-)
When properly adjusted it will not overcenter and you must hold the lever (in my case the old Hurst shifter handle) to apply the brake. Easy peasy... Over centering will definately be an issue, especially in traffic for the folks lined up behind you with the traffic lights on green and your brakes are jammed. Not a good situation!
Without exception, whenever I was at a car event people always asked me 'what the heck does that lever up by the dash do'? Once they understood the mechanics of the device they thought it was pretty cool and asked where I got it from. With a couple of modifications, I made mine using the same picture as a guide in your initial post.
Old 01-30-2020, 12:52 PM
What about Lefthanders BLAIR?
Mount it vertically and use your right hand...it will look much better too.
Old 01-30-2020, 01:16 PM
Ok, So Keith uses his tow bar and tabs, now you just need a drag brake for the 1965 GTO.
Old 01-30-2020, 03:16 PM
John Brown's Avatar
Back when these came out, some drag strips weren't quite as flat as they are now. Some had dips that made a car roll if you weren't on the brake when staged. Some were flat for the quarter mile, but the staging area just behind or right at the starting line were uphill or downhill. Edgewater in Ohio was a prime example, especially if you were staging a long wheelbase car, like a dragster. Quaker City was another. That's why Brannan rigged up a Studebaker hillholder on his 62 and 63 Fords back in 62 and 63. When you travel to backwoods strips, you never know what to expect. It's best to at least be prepared for situations you have encountered before.
John Brown
