Old 03-15-2020, 09:29 PM
169indy's Avatar
169indy 169indy is offline
Originally Posted by rszmjt View Post
What’s interesting in that line picture is that the frame/engine behind the 67 Camaro is not a Camaro subframe , it looks like big car or maybe Chevelle? Makes me wonder if this is a GM staged publicity photo?
Big Car & Camaro built at Van Nuys maybe, (LOS) plant
69 Los Z11
68 SS/RS 396/325
68 Los Z28
Old 03-15-2020, 11:28 PM
rszmjt rszmjt is offline
Did they run different cars on the same line like that? You would think that would be a parts nightmare not to mention specialized equipment like the body jigs shown on the Camaro.
The Following User Says Thank You to rszmjt For This Useful Post:
RobR (03-16-2020)
  #13
Old 03-15-2020, 11:40 PM
The Los Angeles plant started that in '64 when they added the Chevelle to the line with full size cars. They were also the first Chevy plant to change to a "chassis rise" mating rather than the standard "body drop" joining.
Verne
Old 03-16-2020, 12:18 AM
169indy's Avatar
Per the report
LOS - Fisher Body body scheduling code
at the .crg site they talk about Codes on the tag re to body build and this state
Camaros and full-size passenger cars both incremented the same sequence counter.
http://www.camaros.org/numbers.shtml#VINvsStyle
69 Los Z11
68 SS/RS 396/325
68 Los Z28
Old 03-16-2020, 02:00 AM
I assume this is the los plant based on the smog pump on the big block????
Old 03-16-2020, 02:28 AM
70 copo 70 copo is offline
Yes that image back on page 1 is from GM Van Nuys. (LOS)
Towveyor assembly line at LOS.
Fixed Pedestal/Body drop at Norwood. Big difference in the assembly process between the two plants.
Old 03-16-2020, 01:14 PM
Keith Seymore's Avatar
Absolutely.
'63 LeMans Convertible
'63 Grand Prix
Old 03-16-2020, 01:28 PM
jdv69z's Avatar
jdv69z jdv69z is offline
If the pic is from LA, it could be an Impala.
Jimmy V.
Old 03-16-2020, 02:33 PM
Burd's Avatar
Burd Burd is offline
Originally Posted by dmarr35 View Post
shouldn't the heater hoses be ribbed and not GM stamped?
I’ve always wondered this,
It's only Orig once
waste all the rest.
1978 Y88
1995 Q45
Old 03-16-2020, 02:51 PM
I admit, I normally don't restore engines correctly. I am guilty of over restoring, just because it looks better. If I had aspirations of having a car judged (I don't) of course I would do it differently.
Same with the exterior. I couldn't live with the waviness of the seam between quarter panels and the roof panel on my black car as it came from the factory. I re-leaded the seam to get it smooth. I also couldn't bring myself to paint the tail end the same way they did at the factory, leaving almost an inch of panel without black paint; it just had primer way down low in some places. I also improved panel fit (my doors were slightly "twisted") from factory.
I did take special care to get the firewall, heater cover, and "white out" and underside of the car replicated as close as I could. But then, I went with stainless brake and fuel lines so I wouldn't need to take any steps to keep the lines from rusting.
I think if you look at most high end restored cars, they look way better than they ever did on the show room floor. That too can be considered incorrect. Correct?
