Old 04-12-2020, 03:30 PM
1967Z28's Avatar
1967Z28 1967Z28 is offline
Good question. I'll ask him.
Old 04-12-2020, 03:36 PM
1967Z28's Avatar
Speedometer/odometer
Old 04-12-2020, 03:41 PM
1967Z28's Avatar
My friend said "The story we got was that the woman who owned the car got sick and just parked it in her backyard. I checked the motor to see if it was frozen and it is not."
He's going to check the wheel codes.
Old 04-12-2020, 08:17 PM
1967Z28's Avatar
Looks like the wheels are a set from 1973 with the HM code. Matched set with 5/22 on the rear and 5/23 dates on the front. I guess this means the car got mags early on and then they wanted to go back to the stock look but the originals were gone? Don't know for sure.
Old 04-12-2020, 09:00 PM
bummer. set of the jw will set you back some $$$
Old 04-12-2020, 09:48 PM
scuncio scuncio is online now
Neat car - and definitely the coastal rust pattern I used to see when I lived in Santa Barbara.
Old 04-13-2020, 12:36 AM
Baron Von Zeppelin's Avatar
Baron Von Zeppelin Baron Von Zeppelin is offline
Thanks for sharing the find with us.
Never knew California could do that to a car.
Terrible shame it had to happen.
The 70 TA's from VanNuys plant usually have a build sheet in the rear seat springs.
He can save himself the PHS money if he gets that.
These cars pretty much document themselves anyhow when found like this.
7040570 WN Cali emission carb
cast iron intake
#12 heads
big RA exhaust manifolds
VIN on block and trans
VanNuys may have stamped VIN up higher on the block face closer to the passenger head - than the typical area alongside timing cover.
Fremont did that - fwiw.
Never seen one with power locks that didn't have power windows also.
The JW's were probably stolen.
The Following User Says Thank You to Baron Von Zeppelin For This Useful Post:
ZLP955 (04-13-2020)
Old 04-17-2020, 05:50 AM
auwrestling auwrestling is offline
cast iron intake
#12 heads
Vin up top only on Freemont cars
Old 04-13-2020, 11:41 AM
1967Z28's Avatar
That's good info about the build sheet. I've told him to have a look for it.
Old 04-13-2020, 04:01 PM
Here are a couple VanNuys 70 TA docs for reference sake.
Hope he finds the Bsheet
