Old 05-14-2020, 08:24 PM
COPO COPO is offline
Originally Posted by Rumbleguts396 View Post
https://www.ebay.com/itm/Rebuilt-Ori...53.m1438.l2649
This is the Muncie I was considering. Thoughts on it anyone?
Looks like an M-22 assembled August 31, 1968. One easy way to tell is the input shaft on an M-22 will not have any grooves. One groove would be M-21 and two grooves M-20. This identification method works so long as the input shaft is original to the trans, but pulling side cover is always best.
I've never seen a POP that has the letter of the trans stamped regardless of year or build date of the trans. Oct. 1968 is when the A, B & C were stamped as part of the trans assembly date with "C" meaning M-22 which is why the ebay trans is missing the letter as it was assembled Aug. 31st of 1968. .
The Following 2 Users Say Thank You to COPO For This Useful Post:
Rumbleguts396 (05-14-2020), YENKO DEUCE REGISTRY (06-10-2020)
  #12
Old 05-14-2020, 08:42 PM
bergy's Avatar
bergy bergy is offline
The transmission in the link has an assembly date of 9M31
  #13
Old 05-14-2020, 08:51 PM
the427king's Avatar
October 68 is when the codes started to get used based on what i have here.....all the P dated P9P xxx cases didnt have codes [september] I have mixed R or october dates S and T [Nov and dec ] all have codes ...
No Fisher priced toys here
The Following User Says Thank You to the427king For This Useful Post:
  #14
Old 05-14-2020, 09:44 PM
Kurt S Kurt S is offline
http://www.camaros.org/trans.shtml#4speed
To distinguish between Muncie types, if the Muncie was built after 21-Oct-1968, the transmission code contains one of three letters at the end of the build code...
Kurt S - CRG
The Following 2 Users Say Thank You to Kurt S For This Useful Post:
bergy (05-14-2020), Rumbleguts396 (05-14-2020)
  #15
Old 05-14-2020, 10:00 PM
bbbentley's Avatar
Looks nice and correct to me.
FULL OWNER HISTORY
The Following User Says Thank You to bbbentley For This Useful Post:
  #16
Old 05-14-2020, 10:11 PM
Rumbleguts396 Rumbleguts396 is online now
I can't Thank everybody enough for there input. You guys are the Best !!! ROB
1969 Camaro SS 396 X66 Lemans Blue
1969 Corvette 427/390 Lemans Blue
Old 05-14-2020, 10:49 PM
Just so I understand better. The assembly date stamped on it being 9M31. Was this transmission assembled August 31 1969? or 1968? sorry guys I'm just a bit confused and want to understand. Thanks ROB
Old 05-14-2020, 10:58 PM
BARRY BARRY is online now
Default Trans
OCTOBER 21 1968 muncie started the A B C
Barry Allan
The Following User Says Thank You to BARRY For This Useful Post:
  #19
Old 05-14-2020, 11:36 PM
tom406 tom406 is online now
If it were assembled anytime during calendar year 1969 it would have an A B or C suffix as stated. Always a good idea to check casting dates on the case and tail housing and make sure they precede the assembly date by weeks, not years.
The Following User Says Thank You to tom406 For This Useful Post:
  #20
Old 05-14-2020, 11:43 PM
Tranny was built August 31, 1968.
A minor detail, but it has the '70 up style magnetic plugs. Still doesn't prove that case started out as an M22. Anyone can tap the lower boss.
- Warren
The Following User Says Thank You to WorkinProgress For This Useful Post:
