Old 05-23-2020, 03:42 AM
Dayton Dayton is offline
Originally Posted by bluel78 View Post
Do the reproduced ones use the same filter element? Have an original and can't find a filter to fit.
I bought 2 here, http://stevescamaroparts.com
Steve has a NOS case
1969 Camaro
Old 05-23-2020, 05:44 AM
GaryC's Avatar
GaryC GaryC is offline
Your link goes here. casino.
http://stevescamaroparts.com/
Gary
The Following User Says Thank You to GaryC For This Useful Post:
MYSTERYCHEVELLE (05-23-2020)
Old 05-22-2020, 06:00 PM
Definitely some old posts back to 2009. But Good Alternative options mentioned here for air filters. Especially given it will never be seen inside the plenum. CP is a great Conversation piece anytime the hood is open
Old 05-23-2020, 02:03 PM
I believe Steve closed his business about a year ago.
- Warren
The Following User Says Thank You to WorkinProgress For This Useful Post:
Dayton (05-23-2020)
Old 05-23-2020, 09:41 PM
z28s4mjg z28s4mjg is offline
Steve's Camaro's (Steve Pardini) closed his business as Warren stated.
Old 05-24-2020, 11:36 PM
bluel78 bluel78 is offline
I tried Heartbeat's and it's the same as the parts stores AC Delco A697C 8997189. It's roughly 7/16 too tall. Didn't take it back and couldn't locate anything that would work so cut it down and used windshield urethane to bond the rubber seal down to the element. Actually works and looks good but rather spend an hour elsewhere.
Old 05-25-2020, 02:14 AM
May I ask what you tried it in? Meaning a Chevelle unit. Or Camaro??
Old 05-25-2020, 11:32 AM
It's on a Chevelle. Tried the Wix 46948R but it's too short but might use it next time with a spacer.
Old 05-25-2020, 12:22 PM
Thanks. That’s all I was asking.
Old 05-25-2020, 06:25 AM
169indy's Avatar
169indy 169indy is offline
Yes- Correct
I "JUST" tried a New ACDELCO A697X in My NKR Camaro CP (Cowl Plenum) unit with a 16-3/4" diameter lid without any rubber gasket designed and the New filter was to tall. (Bummer)
NKR supplied a WIX 46948R with a rubber compression tube glued to the bottom.
https://www.amazon.com/Wix-46948R-Ai.../dp/B00LFVWPGU
JIM
69 Los Z11
68 SS/RS 396/325
68 Los Z28
