Old 06-04-2020, 04:49 AM
AnthonyS's Avatar
Originally Posted by ssl78 View Post
Also a 1970 power steering set up
I think that's the 71 or 72 and up upper PS adjuster with that square hole for adding belt tension with a breaker bar - the first year (70) ones didn't have that for sure. And that reservoir is not the original (to 1970 or even 1969) banjo type - it's newer / a likely OTC reman unit. IMHO.
Still likely has value to someone though. (that is the one year only 70 upper alternator bracket) Be interesting to see if the lower is flat or creased.
Cheers all.
Old 06-04-2020, 10:24 AM
bbbentley's Avatar
Originally Posted by AnthonyS View Post
...Be interesting to see if the lower is flat or creased.
Cheers all.
2nd pic has a good angle to see lower. Clearly flat.
FULL OWNER HISTORY
Old 06-04-2020, 12:42 PM
TAR6569 TAR6569 is offline
Checked my database, didn't have anything on that partial vin on the pad. Janesville car
381 and counting in the 67-69 Impala SS427 registry
The Following User Says Thank You to TAR6569 For This Useful Post:
McCune (06-04-2020)
  #14
Old 06-04-2020, 01:44 PM
RALLY RALLY is offline
Originally Posted by McCune View Post
I have a 1969 396 that is in a 72 Blazer that his rough very rough. I think this is a passenger car engine? Can someone confirm and a value would be nice to know before I sell the truck too cheap. Thanks for any help.
Jim
Good old 396 2 bbl engine. Low horsepower, good torque and used for pulling. I understand this engine was used in some 69 Impala's back in the day also. No big value on the 396 engine. I bought one years back just to build a 396. Cast crank, 148 open chamber heads, forged rods, nothing special.
The Following User Says Thank You to RALLY For This Useful Post:
McCune (06-04-2020)
