Old 09-22-2020, 01:34 PM
rszmjt rszmjt is offline
I bought some at Lowe’s in Calgary, it is window foam sealing tape, comes in rolls, & different thicknesses.
The Following User Says Thank You to rszmjt For This Useful Post:
X66 714 (09-22-2020)
  #12
Old 09-22-2020, 02:39 PM
X66 714's Avatar
X66 714 X66 714 is offline
I went to Lowe's & their selection was very thin. Same with Home Depot & Ace. Thanks, Joe
Old 09-22-2020, 06:54 PM
Maybe check with a local window manufacturer? Or can you get on line and see what local other Lowes carrys it?
Old 09-23-2020, 05:41 PM
169indy's Avatar
169indy 169indy is offline
Good stuff: Better than Window Home use item.
Grainger (Vendor)
3M
Urethane Foam Double Sided Foam Tape, Acrylic Adhesive, 1/16 in Thick, 2 in X 5 yd, Black
Item # 15C177
Mfr. Model # 4056
UNSPSC # 31201527
Catalog Page # 1392
3M™ 4056 double-coated urethane foam tape roll is an open-cell foam designed for indoor use: mounting soap dispensers and air fresheners, signage, kickplates, and other miscellaneous mounting. Offers excellent shear strength, good temperature resistance, and vibration damping characteristics. Acrylic adhesive.
69 Los Z11
68 SS/RS 396/325
68 Los Z28
The Following User Says Thank You to 169indy For This Useful Post:
X66 714 (09-23-2020)
  #15
Old 09-23-2020, 08:35 PM
Donnie's Avatar
Donnie Donnie is offline
Grainger (Vendor)
3M
Item # 15C177
Mfr. Model # 4056
UNSPSC # 31201527
Catalog Page # 1392
I know your trying to help. but I wouldn't use that its open-cell so it will absorb water. you want closed-cell
69 SS L78 Chevelle
70 SS 396 Chevelle
The Following User Says Thank You to Donnie For This Useful Post:
X66 714 (09-24-2020)
  #16
Old 09-24-2020, 02:09 AM
randy27 randy27 is offline
I noticed the selection from Lowe's here are very thin, too!
The Following User Says Thank You to randy27 For This Useful Post:
  #17
Old 09-24-2020, 08:42 PM
Donnie's Avatar
its in the mail Joe.
69 SS L78 Chevelle
70 SS 396 Chevelle
Old 09-24-2020, 08:45 PM
X66 714's Avatar
Thanks Donnie. Almost ready for it...Joe
Old 09-27-2020, 08:01 PM
EVERY 1st gen I have taken apart has had a narrow foam strip about half as wide as the weatherstrip channel and it is kind of "goooo-ey".
My research indicates the original is a polyurethane impregnated foam seal... I have seen NOS pieces for sale in the past and it looks nearly identical to the set up I have used in restorations and is shown below.
I used a open cell foam and then took a paint brush and coated polyurethane sealer into it then applied. It seals well with no wind leakage.
FWIW 2nd gens used a black foam the width of the trim much like shown above.
X66 714 (09-27-2020)
  #20
Old 09-27-2020, 09:15 PM
X66 714's Avatar
My LA built 68 had that. My Norwood car had different. Maybe they had a couple of different suppliers...Joe
