Old 11-25-2020, 04:00 PM
Thanks everyone for the comments/suggestions! I hope to put some cleaning time in over the holidays! Happy Thanksgiving all!
Paul
'62 Bel Air 409/409
'68 L72 Biscayne
'69 L78 Nova
'17 Denali 3500HD
Old 11-28-2020, 02:10 PM
wthirty1 wthirty1 is offline
For the Olds W-cars, we have aluminum intake manifolds. I've had good luck with vapor blasting the aluminum. It comes out somewhat bright at first but over time the brightness wears away and it looks more like a stock aluminum finish.
1970 Cutlass S W-31 - platinum, blue stripes, blue buckets, M14 3-spd
1970 Cutlass Supreme Y74 Pace Car #79 - IU Little 500 Pace Car
1970 442 - white, red stripes, white buckets, M21 4-spd
Old 11-30-2020, 11:13 PM
Tracker1's Avatar
Tracker1 Tracker1 is offline
Vapor blasting is the best I've seen, I agree. But he doesn't want to remove the manifold from the car so...
I ain't nobody, dork.
Old 12-01-2020, 12:14 AM
mhm1966 mhm1966 is offline
Clean the aluminum intake the best you can. Then use Hi-Temp aluminum paint. Spray a small amount into a container and add lacquer thinner to thin the paint out. Take a stiff bristle brush, dip the brush into the mixture of paint and lacquer thinner and rub the solution onto the intake manifold.
Old 12-05-2020, 04:02 AM
ban617 ban617 is offline
Nice tip on the bristles of the brush , what brand oven cleaner are you using? There used to be a brand Mr.Muscle it would remove the car lot under hood paint jobs in the old days..
