Old 03-30-2023, 06:47 PM
cook_dw's Avatar
cook_dw cook_dw is offline
I emailed Muskegon Brakes as I too need my calipers sleeved . White post quoted over $300 a caliper last year hence why I waited. Muskegon quoted cost of Camaro caliper build to be:
$179.95 per caliper with o-ring seals
or
$129.95 if they use lip seals. Turnaround time is approx 4 weeks.
That's bore, sleeve and test pressures. Survivor style no restoration (paint etc)
"Payment will be collected when they're done and ready to come back to you."
RPOLS3 (03-30-2023)
  #12
Old 03-30-2023, 07:31 PM
427.060 427.060 is offline
or
Was that for single piston or 4 piston calipers?
Edit to add: I just talked to Muskegon. They quoted me $179.95. If they send them to Lonestar, I wonder why Lonestar quoted me $219.95. I guess I'll be sending them to Muskegon.
1968 Beaumont SD396
Old 03-30-2023, 07:34 PM
cook_dw's Avatar
4 piston.
Old 03-30-2023, 07:56 PM
I used Lonestar for my 70 LT-1 Corvette brakes. No issues.
Old 03-30-2023, 08:05 PM
scuncio scuncio is offline
Chemistry is not my strong suit, I have been told by Muskegon that the old formula DOT 5 has not been available for several years and that current DOT 5 is not compatible with the brake parts in our old cars.
Lonestar, and I believe White Post and Karps warranty is voided with DOT 5.
If this is incorrect, please set me straight! - Bill W
That’s interesting, I’ll look into it. As long as you’re starting with a dry system, I’ve never had an issue with DOT5, other than bleeding it every 5 years or so on a preventative basis.
Old 03-30-2023, 09:04 PM
X66 714's Avatar
X66 714 X66 714 is offline
Mike Gibbons say dot 4 when he does brake parts.....Joe
Old 03-30-2023, 09:16 PM
The only advantage to Dot5 is it won't eat paint if you spill.
Old 03-31-2023, 12:32 AM
juliosz's Avatar
juliosz juliosz is online now
My 67 had DOT 5 in it since the early 1980s. The restoration was started in the late 70s and the original owner told me Dow Chemical gave him a couple gallons of DOT 5 to try. Amazingly, when I disassembled the calipers, wheel cylinders and master, all were spotlessly clean and attracted no rust, bores were all perfect as well. I have heard that this is another benefit of DOT 5.
The Following 2 Users Say Thank You to juliosz For This Useful Post:
69M22Z (03-31-2023), scuncio (03-31-2023)
  #19
Old 03-31-2023, 02:45 AM
I like Mike Gibbons. A great guy and easy to deal with. Had several parts done by him.
The Following User Says Thank You to Salvatore For This Useful Post:
X66 714 (03-31-2023)
  #20
Old 03-31-2023, 03:03 AM
Absolutely true - DOT5 will not absorb water, so as long as you keep it sealed to prevent ingesting moisture, it should do a good job of preserving your hardware.
69M22Z (03-31-2023), juliosz (03-31-2023)
