Old 05-27-2023, 11:43 AM
Originally Posted by ALLZS View Post
trying to find some one to re key my door locks to match my ignition key
Sent a PM with contact info for LocDoc
Old 05-27-2023, 01:54 PM
Originally Posted by oldstv View Post
I would like information on this as well, I have a trunk key and an ignition key but no door key. The door locks must have been replaced and the key was lost.
Thank you for posting this.
PM sent with info on re-key contact.
Old 05-27-2023, 06:08 PM
ALLZS ALLZS is offline
thanks guys I will reach out to the contacts and see if they can help thanks
Old 05-28-2023, 01:25 AM
Originally the door / trunk is a different key than the ignition key on a 1969 Camaro No? Bill
Old 05-28-2023, 01:52 AM
KevinW KevinW is offline
No, Factory 69 used for door and ignition the square key and the oval was used for trunk and glove box. Some repro sets have a square key for ign only and oval key for doors, trunk & glove. But that is not correct.
I had one of those incorrect repro set (bought a long time ago) and had to have a local locksmith shop cut some original square key door locks to match the ign key that I had already installed in a real tilt column. They did install the tabbed covers, but once installed, that should not be noticeable (hopefully).
69 327 convertible (driver)
The Following 2 Users Say Thank You to KevinW For This Useful Post:
69 Post Sedan (05-31-2023), X66 714 (05-28-2023)
  #16
Old 05-28-2023, 12:47 PM
Thanks for correcting me. Bill
Old 05-28-2023, 12:48 PM
Oval key fit console door too,when applicable.
Old 05-31-2023, 07:43 PM
soundjunky's Avatar
soundjunky soundjunky is offline
I would love to find someone willing to key me some locks too;
I have the codes, and two of the original tumbers are here, but I want all new coded as original if I can.
My hair brained logic is because GM-Canada still has these key codes on file, and should anything happen, I could (theoretically) be able to go into nay GM dealer, and get a new set of keys for my car.
I had a lead a while ago, but he (like others mentioned here) hasn't replied.
1970 Formula 400
Carousel Red paint on Black standard interior
A no-engine, no-transmission, no-wheel option car.
Quite likely one of few '70 Muncie three speed Formula 400's left.
1991 Grand Am: 14.4 @ 93.7mph (DA corrected) (retired DD, stock appearing)
2009 Cobalt SS: 13.9 @ 103mph (current DD; makes something north of 300hp & 350ft/lbs)
1 Corinthians 2:12-14 / Ephesians 2: 8-9 / Luke 23: 39-43 / 2 Timothy 3:1-5;12
Old 05-31-2023, 11:05 PM
Is this for your '70 Formula ? If so, I can get you contact info. He only does pre 80's vehicles.
Old 06-04-2023, 02:32 AM
Kurt S Kurt S is offline
Key info: http://www.camaros.org/keysandlocks.shtml
Kurt S - CRG
