Old 07-21-2023, 12:39 PM
X66 714's Avatar
X66 714 X66 714 is offline
Here's something from CRG...Joe
http://www.camaros.org/forum/index.p...70204#msg70204
Old 07-24-2023, 05:31 PM
The technical term for the screen in the pic above referred to as "Diamond mesh" is "expanded metal" mesh. The square version (both horizontal/vertical and diagonal) I refer to as "soldered wire" mesh; and for shorthand I call the horizontal/vertical version "square soldered mesh" and the diagonal version "diagonal soldered mesh".
Ignoring the expanded metal ("diamond mesh") filters, the progression for the soldered mesh filters that I have determined from original A212CW filters in their original cars, and from the dates on service replacement boxes for A212CW's and A212CX's (the heavy duty version with an extra layer of the inside mesh behind the outer mesh), is:
- 1965 through approx 2/1968 - Diagonal soldered mesh, no white print, filter number is embossed on the black rubber in large outlined letters.
- 3/1968 - same as above, except the white "BEST WAY TO PROTECT YOUR ENGINE" stamp is added. This pins down pretty good when the white print started, because they had stock with the embossed rubber still on hand that they stamped. Later does not have the large outlined embossing.
- By at least 12/05/1968 - Diagonal soldered mesh with white "BEST WAY TO PROTECT YOUR ENGINE" stamp. Large outlined embossing eliminated. Continues through at least 7/14/1969.
- In box showing 1970 model year as highest year (so could have been made any time between 9/1969 and 8/1970) -- Square (horizontal/vertical) soldered mesh, with white "BEST WAY TO PROTECT YOUR ENGINE" stamp.
- 1972 model year box -- Square soldered mesh, with white "BEST WAY TO PROTECT YOUR ENGINE" stamp.
- Boxes dated from 3/1973 - 11/12/1974 -- Square soldered mesh, with white "BEST WAY TO PROTECT YOUR ENGINE" stamp.
- In box showing 1975 model year as highest year (so could have been made any time between 9/1974 and 8/1975) -- Square soldered mesh, with white "PROTECT YOUR ENGINE" stamp. The "BEST WAY TO" part of the stamp was eliminated. (I would not be surprised if the FTC threatened action for using "best way" in their marketing, without proof that it was demonstrably the best available filter on the market.)
- Boxes dated from 1975 model year - 3/1977 -- Square soldered mesh, with white "PROTECT YOUR ENGINE" stamp.
- Everything after that is the expanded metal ("diamond") mesh. The "PROTECT YOUR ENGINE" stamp continued until at least 5/8/1986. Later filters have just the A212CW stamp.
As to production of the expanded metal (diamond) mesh filters BEFORE 1977, there are a couple pictures of alleged original filters in 1969 Camaro's out there. Unfortunately none of them show which version of the white print they have on them. (I do note that the fantastic low mileage black 69 L78 at MCACN last year had an original diagonal soldered mesh filter in it.)
As far as dated service replacement boxes go, I have recorded the following for the expanded metal filters:
- 2/16/1970 and 5/1970 dated boxes - A212CW with expanded metal mesh, with white "BEST WAY TO PROTECT YOUR ENGINE" stamp.
- 3/1970 and 1970 (no month) dated boxes - A212CX with expanded metal mesh, with white "BEST WAY TO PROTECT YOUR ENGINE" stamp.
- 8/4/1976 and 8/19/1976 - A226CW (cowl plenum) with expanded metal mesh, with white "PROTECT YOUR ENGINE" stamp. (No "best way")
- Boxes dated from 1979 model year through 5/8/1986 - A212CW with expanded metal mesh, with white "PROTECT YOUR ENGINE" stamp.
Cheers!
Jeff Helms
65 Z16 Survivor
65 Z16 drag car
66 Chevelle L78 unrestored
67 Chevelle L78 unrestored
67 Camaro SS350 Survivor
Last edited by jeffschevelle; 07-25-2023 at 04:37 AM. Reason: ERROR FIXED on the two 1976 cowl plenum filters -- They are "PROTECT YOUR ENGINE", NOT "BEST WAY"
The Following 10 Users Say Thank You to jeffschevelle For This Useful Post:
169indy (07-25-2023), 67since67 (07-24-2023), Bill Pritchard (07-25-2023), Charley Lillard (08-02-2023), dustinm (08-04-2023), L_e_e (08-11-2023), PeteLeathersac (07-25-2023), RPOLS3 (07-25-2023), X66 714 (07-24-2023), Xplantdad (07-24-2023)
  #13
Old 07-24-2023, 08:54 PM
John Brown's Avatar
Jeff, did the A212CX have chrome plated wires? I seem to remember seeing some filters that had chrome wire back in my early parts man days.
John Brown
Old 07-25-2023, 04:39 AM
Haven't seen chrome, but really clean NOS filters can have wire that looks shiny.
Jeff Helms
65 Z16 Survivor
65 Z16 drag car
Old 07-29-2023, 12:05 AM
169indy's Avatar
169indy 169indy is offline
Default 1970 Catalog
Info
69 Los Z11
68 SS/RS 396/325
68 Los Z28
The Following 3 Users Say Thank You to 169indy For This Useful Post:
69M22Z (07-30-2023), olredalert (07-29-2023), PeteLeathersac (07-31-2023)
  #16
Old 07-30-2023, 08:40 PM
169indy's Avatar
Page 226
69 Los Z11
68 SS/RS 396/325
68 Los Z28
The Following 2 Users Say Thank You to 169indy For This Useful Post:
olredalert (07-31-2023), PeteLeathersac (07-31-2023)
  #17
Old 08-04-2023, 02:10 AM
SBR SBR is offline
Great information! My friend did find what he was looking for. Thank you for all the replies.
Corvette nut since I was a kid. 67 435s and L88s are my favorites
Old 08-10-2023, 04:50 AM
Did he find an accurate repro? If so, from where?
Jeff Helms
65 Z16 Survivor
65 Z16 drag car
Old 08-10-2023, 10:53 PM
SBR SBR is offline
I believe he found a GM over the counter filter. It has the yellowed paper with the correct square mesh that is rotated 45 degrees. Not totally correct for a 67 Vette as it does not have the correct overlap and is silk screened vs. having the embossed lettering. He just wanted one that had the correct mesh. For 150 he's happy vs paying 5K for an original.
