Old 07-31-2024, 11:52 AM
Be sure to check for bent rods. Also check the block deck and heads to see of they are flat.
John Brown (07-31-2024)
  #12
Old 09-05-2024, 06:05 PM
bav70ss bav70ss is offline
Default Detonation
Originally Posted by bav70ss View Post
We pulled the heads on my 67 Nova SS with a 327 and found coolant in the cylinders. Both headgaskets were toast on my new 700 mile motor. Any ideas as to why this would happen?
After an expensive rebuild of my detonated 327 my builder/machine shop figured out the timing mark on my larger harmonic balancer from a 350 didn't jive with my 327. At TDC the mark was out 14 degrees so he scribed a new correct mark on my balancer.
This wasn't the first motor I lost to a bad timing mark. The first build didn't have forged pistons so it was toast after 40 miles. The 2nd build lasted 700 miles...fingers crossed for the 3rd build!
'70 Nova SS L34, M21, bench seat
Old 09-06-2024, 01:07 AM
I'd be looking for the correct balancer for the 327. They were much thinner and lighter. That 8" balancer might be stressing the crankshaft.
Old 09-06-2024, 04:33 AM
Rsconv68 Rsconv68 is offline
I would like to know which cylinders had coolant. I’d also like to know what valves were damaged, and a lot pictures.
Old 09-06-2024, 12:08 PM
napa68 napa68 is online now
L79's, L76's, and L84's all had 8" balancers
Old 09-06-2024, 12:09 PM
Same engine builder?
Old 09-06-2024, 02:19 PM
I always check the timing mark on a engine that I'm building using a piston stop before putting the heads on. I never trust it until I verify that it's correct. I even verify TDC on a running engine that someone brings to me for tuning using a piston stop in the spark plug hole.
The Following 5 Users Say Thank You to big gear head For This Useful Post:
earntaz (09-07-2024), Igosplut (09-13-2024), Jonesy (09-06-2024), napa68 (09-06-2024), PeteLeathersac (09-07-2024)
  #18
Old 09-06-2024, 09:53 PM
The guywho did the machining did the reassemble this time.
Old 09-07-2024, 12:31 PM
To Freddie's point, I don't know of an engine builder who does a complete build, (including timing cover and balancer) that would not confirm TDC. With the variations in timing covers and balancers, there is no way properly know where the timing is at.
On a different note, did you hear this thing detonating?
Sorry to hear you are struggling like this. After everything you have shared, I believe the time has come for you to find a different engine builder.
The Following 2 Users Say Thank You to napa68 For This Useful Post:
67since67 (09-07-2024), earntaz (09-07-2024)
  #20
Old 09-13-2024, 02:54 PM
Igosplut's Avatar
Igosplut Igosplut is offline
I do the same, I think that's one of the most overlooked things on an engine.
WOT
The Following User Says Thank You to Igosplut For This Useful Post:
earntaz (09-14-2024)
