Old 01-08-2025, 01:47 PM
Hawkeye's Avatar
Hawkeye Hawkeye is offline
Default You are correct
Originally Posted by Too Many Projects View Post
I can't figure out how to include a pic, but they have the collectors welded...
You’re right. I didn’t notice that. I only compared the tube routing and the block flange. Other than some additional holes in the block flange and the welded collector flange they do appear to be same tubes. Perhaps the difference between an actual pair of Hookers and the knockoffs as Tony eluded to??
Cheers,
Marty
Old 01-08-2025, 01:53 PM
seventyLs5 seventyLs5 is offline
Thanks for all the replies guys. The primaries are 1 7/8 on these. I have a 68 Camaro project sitting in the shop that is slated for a big block install so I will give them a shot on that project coming up. They do look really similar to the facebook headers.
Old 01-08-2025, 02:07 PM
1967 4K's Avatar
1967 4K 1967 4K is offline
I’ve always heard that you’ll run into fit issues on a 67 big block Camaro with power steering. The pipes will not clear the unit. Does Hooker or any other manufacturer make a set that will clear the power steering unit?
Thanks,
Richard
1967 Camaro SS 396/375 4K
Old 01-08-2025, 04:51 PM
L78_Nova's Avatar
L78_Nova L78_Nova is offline
Default BB X Headers
This is on a 68 Acadian but should be the same as 1st gen Camaro.
Hooker Super Competition will only fit manual steering.
The #5 pipe is right over the fluid ports on the box
Name:  Super Competition.jpg
Hooker Competition fit although I did massage the #1 pipe at the crossmember because there was next to zero clearance and the #5 at the box because it was aaaaalllllmost touching.
Name:  Hooker Competition.png
The problem becomes hooking up the power steering lines as there is no safe room to run them under. I made hard lines along the box and frame which come through the frame stand (flex end and fitting not yet added to the pressure line). I suppose you could go over the control arm and around but too messy for me.
Size:  59.2 KB[ATTACH]Name:  Mock Up 02.jpg
Size:  50.2 KB[/ATTACH]
70 Chevelle SS-454 LS-5 M-22
The Following 5 Users Say Thank You to L78_Nova For This Useful Post:
1967 4K (01-08-2025), 69M22Z (01-09-2025), dykstra (01-08-2025), PeteLeathersac (01-08-2025), Too Many Projects (01-08-2025)
  #15
Old 01-08-2025, 05:24 PM
Chuck_Burg's Avatar
Thanks,
I have Appliance headers on a 67 Camaro with power steering, no clearance issues at all.
The Following 3 Users Say Thank You to Chuck_Burg For This Useful Post:
1967 4K (01-08-2025), dykstra (01-08-2025), PeteLeathersac (01-08-2025)
  #16
Old 01-08-2025, 05:31 PM
Whoever holds the rights to those headers REALLY should make up 100 sets, as I think they would sell well in this restoration area.
Old 01-08-2025, 08:20 PM
1967 4K's Avatar
Chuck, you didn’t state it but I assume your 67 Camaro is a big block. Isn’t it true that the Appliance brand headers are no longer manufactured?
Thanks all,
Richard
Old 01-08-2025, 11:17 PM
Thanks all,
https://www.yenko.net/forum/showthread.php?t=161440
And no, appliance merged with, was sold to, Doug Thorley in the mid seventies ?
Old 01-09-2025, 12:12 AM
Chuck_Burg's Avatar
My Camaro does have a big block. Appliance Industries is/was better known for their mag wheels but got into the header game in, I believe, 1970. 1970 is the earliest catalog I've seen. From what I understand, a guy named Bob Reagan was the header designer at Appliance. Bob worked for Jardine Headers in Garden Grove, CA. I don't know all the details but Bob ended up going to Appliance and did his thing over there. Appliance headers look similar to Jardine headers from the period with individual flanges. Appliance was located in Harbor City, CA, probably 15-20 miles from Jerry's shop in Garden Grove. I believe the later built headers were made in Mexico. Appliance quit making headers in the mid-late 70s, not sure if they sold to Thorley.... I thought Mr. Gasket bought them and rebranded them as Blackjack, even though Blackjack is nowhere near the quality of Appliance. My friend worked at Appliance in 1979 and the header division was no longer active.
1967 4K (01-09-2025), cheveslakr (01-09-2025), dykstra (01-09-2025)
  #20
Old 01-09-2025, 01:45 PM
1967 4K's Avatar
Sounds like if I want some Appliance headers I’ll have to located some used ones. Chuck is there any part #’s on your headers?
I’ve wanted to put headers on my car for awhile but don’t like the idea of buying a new set then have to beat on them with hammer to make them fit.
Thanks
Richard
