Old 01-11-2025, 05:24 PM
downunder1's Avatar
downunder1 downunder1 is offline
Smile
Hi John,how's your Summer going?
Sounds like you want a Big Block 1970 Alternator belt AND w/o SMOG too,as it wraps around just the crank,water pump and alternator pulley only.Original Part# for that is #3937789 & can be used on ALL 1970 LS-3,L-34,LS-5,L-78,LS-6 applications W/O SMOG.
Quanta sells this GM Restoration/factory correct looking belt as Part# 29B-602,but cross reference with other MFRs.that might have a different look.And I recommend whomever you buy from,call and ask them to confirm the overall length with you first before ordering,as they measure out at just over 46 inches with Deepgroove pulleys when on the car,(at least mine do when stretched.)
Anything longer is a Big Block SMOG PUMP (YE) Belt.
And Power Steering as you know is a separate belt run by the crank pulley only,and not powered by the Alt. belt.
Hi Rick, the summer here so far has been nice and hot, not AZ hot , but hot for us.
We have our biggest car show next weekend.
Thank you for your advice, very much appreciated.
Old 01-11-2025, 05:26 PM
downunder1's Avatar
Thank you, much appreciated.
Old 01-11-2025, 06:06 PM
Donnie's Avatar
Donnie Donnie is offline
I would NOT buy a Quanta belt if you plan on running the RPM's up on the car. IT WILL FLY OFF. If you have a NAPA store take the old belt in and match it up. I'm running a NAPA Gold with no issues.
69 SS L78 Chevelle
70 SS 396 Chevelle
Old 01-11-2025, 06:34 PM
John, if you want me to source some belts and ship them to you, I will.
Let me know
The Following 2 Users Say Thank You to Xplantdad For This Useful Post:
downunder1 (01-11-2025), olredalert (01-12-2025)
  #15
Old 01-11-2025, 08:12 PM
BARRY BARRY is offline
Default Quanta FAN BELTS
my two cents they are a cheap knock off
Barry Allan
Old 01-13-2025, 05:53 PM
L78_Nova's Avatar
L78_Nova L78_Nova is offline
I wouldn't recommend a Quanta unless you are never starting the engine... straight into the garbage,
70 Chevelle SS-454 LS-5 M-22
