Old 06-10-2003, 05:27 AM
Kurt S Kurt S is offline
Default Re: 67 COPO Chevelle ???
Marlin,
They only shared engine codes if the engine assemblies were identical. Same manifolds, distributor, etc. Not sure if any 67 Chevelle engine codes were shared with other 67 carlines. If they were all unique to 67 Chevelle, then that closes that door. [img]/ubbthreads/images/graemlins/smile.gif[/img]
Same thing on axles, that's why the Nova and 1st gen Camaro shared axle codes. Same dimensions, same axles.
Kurt S - CRG
Old 06-10-2003, 12:15 PM
YENKO DEUCE REGISTRY's Avatar
You are correct KurtS. It is believed that Yenko ordered the Deuces with the Corvette LT1, but GM installed the Z28 version due to the exhaust manifolds being the same as the Nova's. The axle codes were also the same for Camaros and Novas through '69, before the '70 Camaro got a little wide! I am not sure what engine would fit into the '66-7 Chevelle without changes, and could share an application code. It's just a thought though!
Marlin
Old 06-10-2003, 01:04 PM
JoeC JoeC is offline
Doug Marion is very knowledgeable and a good writer but I think he is not remembering correctly on the 67 Chevelle. Chevy got tight on HP in 67. They did not offer the 427 425 in the big pass car although some say a few slipped out (less then 10). The 425hp 427 was available in 66 and 68 big cars. Even the 375 hp 396 was hard to get in the 67 Chevelle and many dealers told customers they were not available. So it's hard to believe there was a 427 Chevelle in 67.
