Old 03-03-2004, 08:34 PM
DaJudge DaJudge is offline
Default Re: I'm thinking of buying a GTO
The 68-70 GTO's all had the same style hood.The Ram air hoods had the bracing trimmed to clear the components of the upper ram air pan. Ram Air cars had plastic scoops that were open for Ram Air. The non-ram air cars had closed scoops that were cast out of pot metal. Hide-aways were an option on 68 and 69. Check the rears, you note 12 bolt for the 69 and 70. Pontiacs had 10 bolt rears in those years unless it was a 70 with the 455 engine option, then it got the 12 bolt rear. The 69 GTO you listed in your post would be my first look since it says "WS 400". The WS code is a 400 Ram Air III engine, it may be a 69 Goat with Ram Air. On the passenger side of the timing cover you should see the last six digits of the VIN on the engine block. Good Luck
<span style="color: blue">1970 GTO Judge Ram Air IV, 4 speed</span>
Old 03-03-2004, 08:40 PM
Belair62 Belair62 is offline
Mike...clarify for me...is the VIN stamped on the machined part of the block or the engine number ????
Old 03-03-2004, 08:46 PM
GTO_DON GTO_DON is offline
BOB ITS DON,THE VIN IS STAMPED NEXT TO THE TIMING COVER UNDER THE LOWER RAD HOSE.
1969 GTO convert RAM AIR 4spd
1964 GTO convert survivor
Old 03-04-2004, 02:14 AM
supergonzo supergonzo is offline
The 68 ram air cars had plastic open hood scoops
The 69 ram air cars were opened or closed by a cable which routed under the dash to a knob....like this
Old 03-04-2004, 03:49 AM
I never new that...I thought they only put the engine number on them...makes sense a VIN would be somewhere !On another note....was the front air dam on a 70 semi-gloss,gloss or body color ???
Old 03-04-2004, 04:45 AM
Hi Bob. The front spoiler was a satin or semi gloss black.
