Old 04-11-2005, 12:55 AM
bigiron bigiron is offline
Default Re: 70 GTO with pics
LOOK UNDER GAS TANK OR UNDER REAR SEAT.
Old 04-11-2005, 01:18 AM
By the looks of the paint on the door I would say the car should be Pepper Green and not black; if that door is original to the car.
Old 04-11-2005, 02:30 AM
rh27g8g rh27g8g is offline
Door is not original to car. What are the chances that a sheet could be under tank, if good I will attempt to look there tonite. thanks.
Old 04-11-2005, 05:47 AM
GTO_DON GTO_DON is offline
Baltimore cars have the build sheet inside the car. look behind the seat or check in side the passenger bucket behind the plastic seatback,or under the carpet. whats the code on the rear??
1969 GTO convert RAM AIR 4spd
1964 GTO convert survivor
Old 04-11-2005, 05:59 AM
the code on the rear is for limited slip diff.
Old 04-11-2005, 06:09 AM
But what is the code?? Its on the driver side tube.
Old 04-11-2005, 06:49 AM
Default Re: Help identifying ram air iv gto 1970.
Send them to me at my email address and I'll do it for you.
Old 04-11-2005, 07:02 AM
I have put them on photobucket because they are large. here is the link thanks
hi, i bought a 70 gto over the weekend. It is a black over black 4 speed car. Guy i bought it from has had it since 1981 and has been in garage for last 15 years. He told me it originally was a ram air iv car. It does have the ram air iv hood with some of the duct work. I know it is a long shot and i already sent in fax for phs documents on friday. Car now has 455 in it. Is there any specific ram air iv parts that i should look for ie radiator part numbers. Was there a cable to ram air hood and where did that go thru firewall at. thanks for the help. i have a few pics of car at following link.
http://photobucket.com/albums/v509/dodge6/
Old 04-11-2005, 07:04 AM
hi don,
i couldnt find the code. i will jack car up tommorrow and look harder. what side of axle tube is it on. engine side or rear side. thanks phil
Old 04-11-2005, 08:09 AM
Rear side.
