Old 09-13-2005, 12:46 AM
NovaMob03 NovaMob03 is offline
Default Re: My 6 year quest for a CX coded THM400 just ended
I'm interested. You have a PM.
Old 09-13-2005, 12:53 AM
The vin would also be on the trans
Old 09-13-2005, 03:05 AM
Where exactly would the VIN be on the THM400?
Steve
Old 09-13-2005, 03:09 AM
Did you happen to get the converter?
No 6-point converter! The seller told me he used it for
another project along the way.
I have been told that they are still available from GM. Anybody know for sure?
And, while we are on the converter subject, other than the
six mounting points ( bolts ), is there anything special
about that converter?
Steve
Old 09-13-2005, 03:12 AM
I could use one of those CX M40s. Hope I get as lucky as you.
You GO
Andy,
I ran across another one last year by accident. The seller
started with a $1,000.00 price, then up to $2,000.00, then
all the way up to $4,000.00 ! I bugged-out somewhere along
the way. Too much for a transmission.
Steve
Old 09-13-2005, 03:20 AM
Steve
Look on the drivers side of the trans just above where the pan bolts on
Old 09-13-2005, 04:03 AM
GTO_DON GTO_DON is offline
Thats not where its at on that trans Charley! Try looking on the passenger side of the bellhousing and it will be there. Close to the edge near one of the mounting holes.
1969 GTO convert RAM AIR 4spd
1964 GTO convert survivor
Old 09-13-2005, 04:05 AM
@wot @wot is offline
Could also be along the edge of the bell housing area, near the engine casting number
Dean
Old 09-13-2005, 04:49 AM
Six months is well the within acceptable range. A wider spread is always expected for a high performance big block.
Here you have a solid lifter automatic, not many made. That four bolt block may have just sat in inventory for a long time waiting for assembly.
Tim,
Why would you expect a solid lifter automatic coded big
block to sit around longer? Were the blocks coded ahead
of time? That would defy logic - no? Can you explain?
Steve
Old 09-13-2005, 05:06 AM
Spacing out and thinking Camaro
