Old 03-04-2006, 03:05 AM
fotoboy fotoboy is offline
Default Is it a Copo?
vin:124379n589499
st69 12437 nor 238010 bdy
tr 7157171 pnt
oic x44
Old 03-04-2006, 08:32 PM
Jeff H Jeff H is offline
Default Re: Is it a Copo?
I don't see any COPO's in that VIN range. There was a batch of Yenko's that had VIN's earlier than that car but then there is a jump in VIN's before the next batch. So I would doubt it's a COPO. What are the indicators that make you think it might be a COPO?
Old 03-05-2006, 08:32 AM
has 12 bolt base model no options no fin factory x44 body code. Where do you find a vin list for copo? I found for Yenko
Old 03-05-2006, 09:13 AM
Kurt S Kurt S is offline
It's not.
http://www.camaros.net/forums/showthread.php?t=75624
Kurt S - CRG
Old 03-05-2006, 06:04 PM
The 12 bolt in a COPO would be coded BE...Go look on the pass side axle tube facing the front and write down what the code is.
Old 03-06-2006, 03:37 PM
An X44 could have been a SS 350 w/o style trim. Does it have a small block heater core with the inlet/ outlet to the far right side of the cover? Small block radiator, motor mounts and tranny crossmember?
Paul
Old 03-06-2006, 04:30 PM
Paul
No, you got that backwards. An X11 car could be an SS350. X44 with a small block would be a base car 307 or 350 2bbl motor.
