#11
Chuck Sharin [email protected] Auburn,WA (30 miles South of Seattle) 70 Camaro R/S Z-28, L-78, R/S SS 69 Camaro COPO "recreation" |
#12
check this link to last years rules and tech. ![]() [/ QUOTE ] Thats the one I was looking for!!..thanks! ALbert
1969 9566AA COPO Chevelle M-22 1969 Malibu 489 ZL-1 T-56/4.56 1969 Beaumont 540 th400 3.70 1969 Chevelle 300 Deluxe 427 ZL-1 M 22W 1970 Olds 442 W 30 2 door post 1969 Ply. GTX 426 hemi auto. Blue. 1940 Dodge pick up Durango 4X4 1968 Camaro ragtop LSA ZL1 |
#13
Looks like everyone hit the high points...
[*]13.99 and quicker means a helmet is *required*, but we encourage EVERYONE who makes a pass to wear one...cheap insurance if you ask me... [*]No shorts, gotta have pants...ask Dave H about getting tossed for that...sweat pants is an easy fix, just don't expect any cat calls from the gallery... [*]No open toed shoes...this means no sandles...cowboy boots or velcro shoes are optional... [*]Shirts with sleeves are required...no tank tops, cut off shirts, half shirts, or whatever...short sleeves are fine, a light shirt with long sleeves so we can easily see 'em in the lanes is better (I get tossed over my sleeveless shirt at least once a season!)... [*]Seat belts...that's a no brainer. [*]Overflow tank...we would really like to see everyone with an overflow tank, but if you're just gonna make a few easy passes then we can probably let it go a couple times...but for you hot-lappers out there, it would be nice to see a catch-can of some kind...as Clill said above, I simply run a piece of hose from the rad overflow to my washer bottle...also, we've used cans/bottles and such in a pinch...it doesn't have to be permanent, that way you can take it off for the eye candy folks on Saturday... [*]2, count 'em "2", return springs...just stop by an auto parts store and grab a cheap throttle return spring and put it over the original...I've seen what happens when this goes awry, and a spring is an easy on/off safety net... [*]Common sense stuff...lugnuts tight, brakes working, not puking fluid out, no fuel leaks...it's gonna be your butt driving the thing, but don't get stupid by getting lazy... [*] Like someone said above, go *around* the water box, then back up and do a dry burnout...unless you're one of the more serious guys with some tire under the car, then the water is just gonna make getting the car off the line a chore... [*]Do me a favor, and take it easy on the "go pedal" in the pits...seems like each year I take a butt chewing from the track folks about someone doing burnouts or hot rodding through the pits...if you're gonna play, play on the track... [*]You'll also need to fill out a brief tech card...I'll be handing these out, but everyone will need to fill one out...if I don't find you, then FIND ME...look by the BIG black trailer...also, we're gonna be looking at doing an informal, and more importantly laid back, bracket race...it's not gonna filled with ringers, so don't worry if it's new to ya...but in a bracket race *everyone* has a chance to win, regardless of whether it's an 11 second ride or a 16 second ride...we'll walk everyone through it, but it will be later in the day... Now, with all that said, DO NOT LET ANY OF THE ABOVE DISCOURAGE YOU FROM RACING! If you forget something, or have a question, or have never been on/around a track before, PLEASE ASK! Probably just about any shmoe walking by that day would be more than happy to lend a hand, or will at least know where to find someone that will! You won't be alone, as a day at the track isn't second nature to everyone...there's always someone who needs to borrow a helmet, or a spring, or some tools, or whatever...no big deal, just ask! Most importantly, come to HAVE FUN, and things will work themselves out... ![]() |
#14
New for the track this year..
![]() ![]() No charge!
20 foot 75 hp good time at the lake |
#15
Rob....a couple things....1. take off the hub caps...seems every year we are chasing someone's caps down the track...2. don't fill the tank full of fuel or make sure your cap seals...for some reason the guys at the start line don't like 110 octane fuel coming out of the tanks. Windows must be rolled up when making a pass. Last but not least.....don't run over the fat guy helping at the start line!
#16
Annie
[ QUOTE ] Rob/Tom...can you help us out here please....I can't remember what the time cut-off is for helmets. [/ QUOTE ] Rob [ QUOTE ] 13.99 and quicker means a helmet is *required*, but we encourage EVERYONE who makes a pass to wear one...cheap insurance if you ask me... [/ QUOTE ] Great! Now we have to allow Annie an additional two hours between rounds to fix what the "helemt" did to her hair! ![]() Rick
Rick Nelson Musclecar Restoration and Design, Inc (retired) www.musclecarrestorationanddesign.com https://www.youtube.com/watch?v=62r-6vgk2_8 specialized in (only real) LS6 Chevelle restorations |
#17
Just an additional note on why you should avoid the water if you don't have slicks: The water gets trapped in the treads, then dribbles out and tracks all the way up to the line. Bad for traction.
Verne ![]() |
#18
Can't believe I forgot this one, but I would give bonus points to those of you with driveshaft loops! Ever seen a car lose a u-joint and do a pole vault? Another memorable experience shared by Dave H...! They make some that bolt to the rear of your tranny's tailshaft, so no welding...
#19
Ever seen a car lose a u-joint and do a pole vault? [/ QUOTE ] Northstar Dragstrip, MN circa 1978. Vega station wagon with a built 396 gets about 15 feet out of the box and twists the front U-joint off the driveshaft. The shaft falls to the ground, digs in, cartwheels the car in the air to the point that the rear end broke loose from it's mounts rotating upwards to the point where the rear joint now fails. The shaft continues on it's travels and punches a hole in the floor pan and out the rear tailgate. Not a pretty site and good thing he was only getting started down the track. ![]() Rick
#20
Gea thanx Ric, maybee that 2 ours wuld be beter spent teeching me how to spel...!
Verne, I have wondered why I was told to drive around the water but wasn't smart enough to ask....now I know. Thank you! Maurice.....300 lb weight requirement???!!!!!!! That is a boat load of chocolate I am gonna have to eat between now and race day! I promise to not run you over at the start line although I have been told I don't see as well as I used to but I think a certain old goat is just trying to get me to stay home. On a more serious note, please take Rob's encouragement to heart. Last year was the first time I took a car down the track and it was FANTASTIC! Times don't really matter, being safe and having fun DO matter. I was so nervous I almost had to drop out as my legs were shaking so bad I could hardly keep them on the pedals! Half way through the 1st pass I was hooked! Made two more runs and have been excited about this year ever since. And Rob is right, there are plenty of fellow racers and members more than willing to lend a hand and/or answer any questions. I am sure if Andrew is announcing again this year, he will even walk you up to the start line and give you a few pointers. If he isn't available, I know Big Bad Mo, Tom, Rob and several others will do the same. See all of you in a few weeks! A |
