Old 01-23-2008, 09:16 PM
Casey Marks Casey Marks is offline
Default Re: 69 Camaro Manual Steering Box Rebuild
A good hi-temp wheel bearing grease is all that you need. Lube the worm gear with gear oil, fill the box with the wb grease, and call it good ....
I'm giving all my secrets away .... dang .....
Old 01-24-2008, 12:02 AM
m22mike's Avatar
m22mike m22mike is offline
Just a side note, at re assembly, put some thread sealer on the threads of the large cast end cap.
This will keep that ever appearing drop of oil from forming
Mike
Old 01-24-2008, 12:05 AM
Now there is a man comfortable in his profession. Thanks Dude!
Old 01-24-2008, 04:09 AM
.... Worst part might be getting the pinion arm off.
That would be called the PITMAN arm ......
