Old 05-13-2008, 01:51 PM
@wot @wot is offline
Default Re: NGK vs. AC Delco spark plugs
The pics you posted show two different types of plugs, one is a projected nose, the other is not. If you don't want a projected nose, and can't find a NGK "normal" cross reference, go to a racing plug if you can find the right heat range. I use a cold NGK racing plug in my L78, and they work fine. They are a .460 reach.
Dean
Old 05-14-2008, 05:47 AM
70 Forest Green Zee's Avatar
Update to this whole story...I put in the NGK XR5's and they run great...after Marlin's post I wasn't too worried because he has the same engine in his Deuce as I have in my 70 Z28. Bottom line, so far from how the car runs with the NGK's, I like um!
1970Camaro Z28
Old 05-14-2008, 05:50 AM
njsteve njsteve is offline
Those NGKs are great. I switched out the hemi and the 455HO to NGKs from Autolites and it was a noticeable difference.
Listen for yourself:
455HO with Autolites:
455HO with NGKs:
Old 05-14-2008, 05:57 AM
firez firez is offline
i took my 68 Z out for the first time this spring with set of the NGK XK5s and the car ran perfect. Car seemed to rev up quicker with the NGKs.
1968 LOS Rallye Green Z28
Old 05-15-2008, 08:41 AM
RamAirDave RamAirDave is offline
Picked up some XR5s this afternoon, and theyre a gold cad type color rather than the silver in the pics above.
Could probably live with the silver, but dont think I can handle the gold Think I'll scuff, mask, and put some hi-temp black on the area that shows while I'm going through the distributor.
TheMuscleCarGuys.com
Old 05-21-2008, 09:01 PM
Chevy454 Chevy454 is offline
If you don't want the projected tip, you could go with a YR5 / 7052 (same as UR plug except w/ non-projected tip)...
Old 05-30-2008, 04:58 AM
Dog427435's Avatar
Dog427435 Dog427435 is offline
Don't know if this will help -
Old 05-30-2008, 06:41 AM
I swapped out my Delco R43T for NGK UR5 last year and it really gained some get up & go..
