Old 02-22-2006, 12:54 AM
njsteve njsteve is offline
Default Re: 72 T/A progess
I don't know about McGyver but I feel more like Cliff Clavin on Cheers sometimes:
"As a matter of fact there Normy, the 1972 Camaro and Firebird, or F-Bodies as they are more commonly referred to by those in the know, were the lowest production year of any of the years from 1967 to 2002 due to the fact of a full strike against the Norwood Assembly Plant was instituted by the United Auto Workers, resulting in thousands of unfinished cars left on the assembly line being scrapped as they would not have passed the more stringent 1973 emission and bumper standards...."
Old 03-13-2006, 04:54 AM
I took a little break while getting the Camaro sold and delivered, so now it's back to work. I sent the original radiator out to be recored and got it back a week later. I went to reinstall it and it wouldn't fit. Very strange, it was 3/4" too wide for the saddles. The following Monday I called the radiator guy (very reputable, long-time radiator overhauler and custom tank fabricator) and he was scratching his head also. Until finally he says: "Hey wait a minute I was recoring a Camaro radiator the same week...could I have switched the cores? He picks up the phone and calls the Camaro guy and asks him if he installed the rad yet. The guy says: "I was just about to, right now." The rad guy tells him: "Just bring it back now, I'll explain later." Turns out he did swtich the cores and there was a 3/4" difference in the widths for the same year cars. He redid my radiator with a new corre (and the other guy's too) and had it back to me in a few days. No charge. I have to say he was a stand-up guy about the whole thing, no questions, no excuses. You don't find that very often these days in service industries. I would definitely recommend him: Arts Radiator Fabrication in Flemington, NJ. He was surprised that I wasn't angry. I explained it this way: if it was a simple mistake that I could have made, there is no way that I would fault anyone else for making the same mistake. So I guess the lesson for all of us is the old saying: "measure twice and cut once." Or in this case: "measure twice and install once."
I also found a correct, original master cylinder on ebay for $18, complete with the bleeder screws and had my local auto parts store send it out and had it rebuilt. I installed it and filled the system with silicone brake fluid and bled it. I prefer the silicone fluid on restorations because if you ever have a leak or a drip, it won't hurt the paint. Easy insurance.
Old 03-13-2006, 04:58 AM
I found another 1971-72 charcoal cannister and restored that. My original had some slight nipple damage (insert joke here) from the previous owner's fire. Being the dummy that I am I always wondered why they called it a charcoal cannister. That was until I pulled the filter off the bottom while having it right side up. Here's what came out: about two pounds of charcoal.
Old 03-13-2006, 05:02 AM
Here's the new one back in the car. I reused the original hose clamps after cleaning them up a little. I went to the local pet store and bought two pounds of activated charcoal (for fish tank filter use) and poured that into the cannister and then capped it off with a new filter on the bottom. I then reinstalled it on the base and bolted it back up to the radiator support. It should actually work as intended now.
Old 03-13-2006, 05:47 AM
Wow Steve...looking great! This is better than any restoration book...
Old 03-13-2006, 06:59 AM
But now you have cheap repo charcoal in your car...
Old 03-13-2006, 07:02 AM
Well, as a matter of fact there Normy, if one were to perform carbon dating on both samples of charcoal they would both date back to the early Pennsylvanian period, when the majority of the Earth's coal supply was formed.
-Sincerely, Cliff Clavin
Old 05-26-2006, 12:57 AM
I've been working on my other project lately (1987 IROC Z) and have been collecting parts for the T/A. I recently received my Gardner exhaust system and trial fitted it this afternoon. Amazing quality stuff! It took longer to bolt up the hangers than it did to hang the entire system. Everything slid into place by hand. The only problem I ran into was trying to finagle the intermediate pipes under the car without the car being on a lift. I was like one of those twisted nail puzzlers that you see in novelty stores. There was only one way to move, twist and rotate the pipe(s) around to get them into place. But after using my brain and lifting the car as high as possible on the jack stands, they eventually fell into place. I highly recommend their products. I trial fitted (no clamps) everything so I can start the car with an exhaust in place. The engine hasn't been run in 6 months or so and now that I have the radiator, power steering and everything else hooked up I want to get it sorted out. I'll try to link some photos in the next day or so.
Old 05-26-2006, 02:06 AM
Here are some photos of the Gardner exhaust trial fitted to the car. The pipes hung perfectly -no tools required.
Old 05-26-2006, 02:20 AM
Once in a while you actually find a bargain on ebay: I have been looking for an NOS front spoiler for the T/A. When you can locate one they run between $300 and $400 dollars. The reproductions are total garbage. This one was somewhat mis-described in its auction and I ended up getting it for $128! It is definitely an original NOS GM piece that came factory pre-painted in white. Here it is alongside my slightly used (smashed and burnt) original one:
