Old 06-08-2023, 10:42 PM
Sounds like it's low on fluid. If it was working good and this is a sudden change, check the fluid. The modulators on them are known to rupture the diaphragm and suck the fluid into the intake and burn it, so there won't be an obvious leak.
Old 06-13-2023, 11:10 PM
TomN TomN is offline
Yeah - I had hoped that would be the problem, but the transmission was full. Anyway, the trans is out, it has been rebuilt - now to get it back in. That should be soon - but first I'm going to fix a driveshaft safety loop. I have been having a little problem getting the right clip that holds the speedometer drive gear in place on the output shaft. Shop kept giving me the wrong part - but I believe we've got it worked out now and I can get the right clip in the morning. I thought while everything was apart I would get it fixed so the speedometer would read correctly.
The Following 3 Users Say Thank You to TomN For This Useful Post:
COPO (06-14-2023), olredalert (06-14-2023), scuncio (06-13-2023)
  #213
Old 06-14-2023, 07:56 PM
Sounds like you will have a fresh trans now. Out of curiosity, did you check the fluid level with the engine running or turned off?
Jason
Old 06-14-2023, 11:25 PM
Running - with the engine and trans warm.
The Following 2 Users Say Thank You to TomN For This Useful Post:
69M22Z (06-14-2023), SuperNovaSS (06-15-2023)
  #215
Old 06-17-2023, 02:56 PM
So I did get the right clip to hold the new plastic speedometer drive gear in place - so that all worked out. Next I installed a kit from B&M to recalibrate the governor. I wanted a higher RPM upshift. And I used a kit from TransGO to reprogram the valve body for a quicker + firmer shift. But the trans is still sitting in the floor - I've got to get to it.
The Following User Says Thank You to TomN For This Useful Post:
Xplantdad (06-17-2023)
  #216
Old 06-17-2023, 05:56 PM
Hey, you made progress, more than some do. You'll get it in...
COPO (06-18-2023), TomN (06-17-2023)
  #217
Old 07-09-2023, 09:20 PM
Well the transmission is back in. Don't know why but I had to re-adjust the shifter cable. Trans work good so I'll try and get out drive it some and enjoy it for a while. That will give me a chance to tune on the engine and try to get the best performance. Now on the getting the gears changed it the rear end.
The Following 7 Users Say Thank You to TomN For This Useful Post:
COPO (07-10-2023), dykstra (07-11-2023), John (07-10-2023), L_e_e (07-09-2023), PeteLeathersac (07-10-2023), SuperNovaSS (07-10-2023), Xplantdad (07-09-2023)
  #218
Old 07-30-2023, 12:41 AM
Sorry I didn't get to bring my Chevelle to the SCR. I didn't have the new rear gears in, but then I wasn't feeling the best and didn't feel like I could load the car in the trailer and all anyway. Maybe next year - I hope.
big gear head (07-30-2023)
  #219
Old 08-24-2023, 06:03 PM
The 3.73 gears are sit-up in the rear end now. My neighbor finally got to it for me. Now to pull the 3.08 rear end out and put the 3.73 in. Should have it all done in a few days. I know I'm slow at times - but I keep moving in the right direction.
The Following 4 Users Say Thank You to TomN For This Useful Post:
COPO (08-24-2023), dykstra (08-25-2023), L_e_e (08-24-2023), Xplantdad (08-24-2023)
  #220
Old 08-24-2023, 09:58 PM
Are all the bushings good in the rear suspension ? May as well address those, while it's out.
