Old 01-03-2019, 07:41 PM
For the interior dash plaque its not out of the realm of possibilities that the original dealer installed as part of the prep. If it was missing from the factory or damaged somehow they may have simply went to their stock and installed what was there. Not sure how you would look at this then. The car should have had a 69 version but eneded up being delivered to the OO with a 68 version.
Without being there yourself when the OO picked it up, you may never know for sure. memories get real fuzzy on this detail stuff after 50 years!
Owned since 1978 - First Car
Old 01-03-2019, 07:51 PM
SS427's Avatar
SS427 SS427 is offline
In that case if it could be somehow authenticated I would likely restore it how it SHOULD be not how it was. If I hear from other COPO owners that have the 68 then I will leave it. However, as so many of them have been previously restored that may not be the answer either.
Rick Nelson
Old 01-03-2019, 08:31 PM
SS427's Avatar
Heard from another 69 SS396 owner and states the same as you Sam, 15/16".
Rick Nelson
Old 01-03-2019, 08:40 PM
tunes's Avatar
tunes tunes is offline
I'll confirm what Sam has said about the wheel cylinders. I pulled these original cylinders from my '69 Chevelle, KK 4.10 axle and they are 15/16.
Robert
_______________
2023 Stingray Coupe Z51
The Following User Says Thank You to tunes For This Useful Post:
SS427 (01-03-2019)
  #225
Old 01-03-2019, 08:44 PM
SS427's Avatar
Maybe that 3/16" rear brake hose is somewhat standard too. I just have not laid hands on enough 69's to know.
Rick Nelson
Old 01-03-2019, 11:55 PM
wheelhop wheelhop is offline
I have seen them on "early" 69 chevelle SS cars like the black chevelle Ryan has described in an earlier post. Not sure about COPO's or Yenko's.
Old 01-04-2019, 12:53 AM
camarojoe's Avatar
Originally Posted by 21superboat View Post
If i had to choose based on appearance and correctness a 69 malibu dash plate would be the way to go. Who knows how a 68 plate wound up in there but i wouldnt put it back unless there are other documented 69 yenkos confirmed being delivered this way
I just said, there are indeed others that were delivered this way. I recalls specifically asking the owner about it on the white sYc Chevelle and he didn't even know what I was talking about until I pointed it out, and said that it's the same spear the car always had as far as he ever knew. I have no reason to believe yours wasn't that way since day one as well. I absolutely would restore it the way it was delivered, including the 68 dash spear.
Joe Barr
The Following 2 Users Say Thank You to camarojoe For This Useful Post:
62sedan (01-06-2019), SS427 (01-30-2019)
  #228
Old 01-04-2019, 01:43 AM
Slob44 Slob44 is offline
Default rear brakes
Rick
My June built Baltimore 69 SS vert had the 940 15/16 rear brake cylinders and the 3/16 inch rear brake line
The Following User Says Thank You to Slob44 For This Useful Post:
SS427 (01-04-2019)
  #229
Old 01-04-2019, 01:52 AM
Default thanks
Rick
I wanted to say thank you for taking the time to post all of this information. it has been extremely helpful!! I just got my car back and started the rebuild process. Your insight, pictures and processes have me rethinking and re-doing processes I have already completed. it is a true inspiration
Old 01-04-2019, 02:11 AM
Originally Posted by Ryan1969Chevelle View Post
Dan Vasic has a black 1969 shell restored and by memory it had the 68 dash trim piece.
Maybe 5 years ago.... let’s test my memory of tiny useless details :-)
Ryan W31
Ha, Ryan try more like nearly a decade ago....Ryan has the Best Memory, LOL.
Rick, I would DEFINETELY use the original as found name plate in your Yenko Chevelle.
We have seen this and we have learned that it did happen.
https://www.yenko.net/forum/showthre...Black+Chevelle
camarojoe (01-04-2019)
