Old 12-02-2008, 06:32 PM
Chevy454 Chevy454 is offline
Default Re: really cool 70 Z28..simply the best.
Check the original bat wing (assembly line) wheel weight!
And it ain't no leight-weight, either! Looks like that wheel/tire balanced about like all of my repro tires have...!!
Old 12-02-2008, 07:18 PM
al8apex al8apex is offline
Points deduct for too much goop...
LOL! you will just have to "restore" it to what it should be then ... j/k
Jim R
Scottsdale, AZ
Old 12-02-2008, 07:44 PM
wwchevy wwchevy is offline
Absolutely Amazing that the clock stopped at the exact moment Doris dinged the door.......I think????
Old 12-02-2008, 08:23 PM
Wow, my LA built Z28 was built about a week earlier (03B). I wonder if it has a buildsheet tucked in the right front fender?
Paul
Old 12-02-2008, 08:47 PM
VintageMusclecar's Avatar
Notice the yellow paint dab on the dist.
Charley;
Is there a similar yellow paint daub on the drivers side rear corner of the baseplate on the carb? I've had a number of unmolested `70 BB carbs in which all had a yellow daub, just wondering if the LT1 got it too.
Thanks.
Eric
Old 12-02-2008, 08:48 PM
DarrenX33's Avatar
pic of a build sheet still bolted to inner fender and taped to the firewall. Would be gone if it ever got wet.
1969 Z28
1972 Corvette
Old 12-02-2008, 10:11 PM
I'm guessing the white mark was to know where to put the weight.
Yes.
And they used different color wax blobs to indicate the different weights...
Old 12-02-2008, 10:28 PM
You can just imagine that build sheet taped to the firewall and when the assembly line worker comes and lines up the front clip to the car it get pinched in between the fenderwell and the bracket...Amazing.
Old 12-02-2008, 10:41 PM
It is amazing... just like what I am sure is a Chassis build sheet on the rear... like john Z said... all the sub assemblies subframe, rears, body, front sheet metal, etc... had build sheets taped to them, when the cars went together the sheets were supposed to be pulled off and disposed of...
They left so much on this one that if you threw a Just Married sign in the window, it would have been right at home leaving a church as an assembly line! BUT CAN I HAVE IT!!! PLEASE?
Old 12-02-2008, 11:19 PM
Stefano Stefano is offline
I'm confident that some of the same "build Sheets" etc.. were left on other cars. They just didn't Survive like this one.
