Old 03-09-2020, 02:29 PM
Edgemontvillage's Avatar
The second wrench-handle installed
Current view of the front of the shop
The Following 3 Users Say Thank You to Edgemontvillage For This Useful Post:
Canuck (03-09-2020), markinnaples (03-09-2020), RPOLS3 (04-20-2020)
  #262
Old 03-09-2020, 04:14 PM
The next priority is to create an appropriate place for (dry) media blasting and other shop activities that produce a lot of dust...and fallout. Our dry media blaster is located in the compressor room however the cabinet doesn't seal well enough so even a short session leaves the room covered in glass bead fallout. It requires a lot of cleanup which is time consuming and its no bueno for the longevity of our spendy compressor. The compressor room also houses the ceramic media tumbler and some minor storage so there's not a lot of elbow room for working around the blaster. We already have a 20' storage container and don't want to devote that much space for media blasting so instead we wanted to source a 10' container - that would be the ideal size. Turns out they are not very common (here anyway) and the price point is only slightly less than a 20 footer. Rather than buck-up we instead bought a 20' container - cut in half! We found a company that, among other things, buys 20' & 40' containers then re-engineers them into mobile offices and a variety of different uses for the movie industry, which is very active in our city. We wanted to find a cheapie container and that's what we got. Its well traveled with plenty of dents and scars but it's perfect for our project. We negotiated a good price and managed to find a new steel door amidst the mess of the sellers shop and we got a good deal on that too.
Here's our half container...with a half a truck sitting on top of it...
Our cut container and our NOS(?) door
The seller's shop...chaos
We arranged for the seller to deliver the cut container to our shop the next day which worked out well as he has a 5 ton flat deck with a boom crane
A short time after the crane set down the container one of the 3 truck batteries exploded!. It threw plastic shards from the battery case well into the air and dumped acid everywhere. Had the battery "let go" just a couple of minutes earlier the operator would have been injured as the boom controls are located directly above the offending battery!
Once the container was relocated to the back lot...shuffled through the shop via forklift, a new tongue & groove floor was installed and the open end of the container was framed, sheathed, wrapped, the base of the door frame was blue-skinned, then the wall was insulated, vapor barrier was installed and plywood added to the inside of the door-wall. The NOS (lol) door was then installed and plumbed true.
As we plan to clad the front of the container with the same galvalume corrugated steel we've used extensively on the building we installed J-trim around the door and edges along with drip flashing above the door and at the bottom of the front elevation.
Still a long way to go; cladding, electrical, air line, flooring and, when the weather improves, painting to follow.
The Following 2 Users Say Thank You to Edgemontvillage For This Useful Post:
HawkX66 (03-10-2020), MosportGreen66 (03-15-2020)
  #263
Old 03-09-2020, 04:59 PM
Originally Posted by firstgenaddict View Post
You can buy a manometer pretty inexpensively, port one side to the booth and one side to post filter and it will give you a difference in air pressure, tell you if you've got too much fan and also easier to determine when to replace your exit filters.
Thanks James, that's worth exploring. The Eaton fan controller we installed provides infinitely variable fan speeds for all types of painting and has proven a great addition.
Old 03-15-2020, 02:40 AM
Getting some of the cladding installed on a rainy weekday evening
The fully clad and trimmed front of the seacan. Painting of the rest of the container will have to wait for warmer weather. Next is interior floor covering (decking material).
The Following 4 Users Say Thank You to Edgemontvillage For This Useful Post:
HawkX66 (03-16-2020), MosportGreen66 (03-15-2020), Xplantdad (03-15-2020), YENKO DEUCE REGISTRY (03-16-2020)
  #265
Old 04-19-2020, 01:43 AM
Now that the open-end of the blasting shed is enclosed and weatherized we turned our attention to interior finishing. To clean, seal and brighten the travel weary half-container we gave it a couple of coats of KILZ primer which adheres well and covers everything. As we had already laid new T&G plywood floors and applied joint filler-sealer (and sanded it) we decided to install 60mil exterior vinyl decking for durability. The vinyl was cut to measure then adhesive was rolled onto the fuzzy backing and the plywood flooring, booked, allowed to set up then applied and rolled smooth - a lot like hanging wallpaper actually. Everything but the seam sealer was completed. Would have got to that save for the Olfa knife incident...it will have to wait for another day.
We had a warm day for the job so the vinyl was left out to absorb some heat to make it more pliable.
One step closer
The Following User Says Thank You to Edgemontvillage For This Useful Post:
HawkX66 (04-20-2020)
  #266
Old 04-20-2020, 01:51 PM
enio45 enio45 is online now
Im certain no work is planned for this shop!!
Might be a She-Shed in disguise!
Eddie M
Camaro-less
87 El Camino SS
Few Ferrari's
Old 04-20-2020, 05:11 PM
Canuck's Avatar
Canuck Canuck is offline
Eddie
Rest assured work is being done.
The She Can as we will call it will house our media blasting.
Our older blaster was in the compressor room and the dust was a concern as it was so close to our compressor.
Our new Modu-Blast arrived last Tuesday with some assembly required.
Like a colt getting its legs,it stands up for the first time.
We will re seal the old Eastwood cabinet and use a different abrasive in it.
We haven’t selected any visual accessories for the She can but Popouri and Velvet Tiger paintings are being considered.
www.vancouverclassiccars.com
The Following User Says Thank You to Canuck For This Useful Post:
olredalert (04-20-2020)
  #268
Old 04-20-2020, 10:49 PM
Tracker1's Avatar
Tracker1 Tracker1 is online now
Lloyd, how many paper bags did you go through calming your hyper-ventilating while you were here:
I ain't nobody, dork.
Old 04-20-2020, 11:18 PM
They just needed a little help getting organized.
Canuck (04-20-2020), enio45 (04-21-2020), Tracker1 (04-21-2020)
  #270
Old 04-21-2020, 01:04 PM
Where is the Vapor blaster ?
