Old 08-03-2008, 06:52 AM
meneed69z28bad meneed69z28bad is offline
Default Re: Just purchased 1969 435 hp corvette,is it real
http://100megsfree4.com/corvette/1960/vet69.htm
this website says that the corvette vin# start at
194689S100001 to 194679S138762 can someone tell me why this vin# is 194679S709381
Old 08-03-2008, 09:07 AM
John Brown's Avatar
Final monthly serial number for 1969 production according to NCRS Corvette Pocket Spec Guide;
September 68..... 703041
October ......... 706272
November ........ 709159
December ........ 711742
January 69 ...... 714695
February ........ 717571
March ........... 720543
April ........... 721315
May ............. (no units built)
June ............ 723374
July ............ 725875
August .......... 728107
September ....... 730963
October ......... 734067
November ........ 736798
December ........ 738762
I'm not a big enough Vette fan to know if Corvette had an extended build year in 1969 or if some of these are 70 production. These are only listed as final monthly serial numbers.
John Brown
Old 08-03-2008, 10:23 AM
I understand that 435/427s were the only 69 Vettes with a single fuel line (no return line) from the factory.
John,
The 427-400hp ( L/68 ) while an oval port engine - used the
same tri-power carb setup as the L/71. The L/36 was the only
Rochester 4-bbl setup on the 427 in the Vette during 1969.
Steve
Old 08-03-2008, 05:01 PM
SBR SBR is offline
John,
The 69 production run was extended to Dec of 69. That accounts for why there were so many 69s over 38K and so few 70s about 17K I believe.
Corvette nut since I was a kid. 67 435s and L88s are my favorites
Old 08-03-2008, 06:54 PM
TimG TimG is offline
I don't know if the car is a legitimate 435, but the motor is restamped. Funky "3's" among other things.
Old 08-03-2008, 08:09 PM
70 ls6 convert 70 ls6 convert is offline
Thanks for all the good info,i will take a picture of the spindles,any trick on getting better pictures of the trim plate and engine stamp,i try and get a close up and it gets blurry,
Old 08-03-2008, 08:24 PM
92646 92646 is offline
It has worked for me in the past. If I take the car outside in the sunlight and turn the flash off on the camera. I can get closer for better detailed pictures.
Mark Sheppard
Old 08-03-2008, 08:25 PM
70Z28RS5151 70Z28RS5151 is offline
Set your camera to macro mode, if it has one. My 8 year old Sony has a tulip as a symbol near the setting buttons. Don't use the flash.
Old 09-25-2008, 08:19 PM
Update..this car turned out to be a complete fraud,engine had 2 bolt cap block,who knows what else he did?..he has other vets for sale,with the threat of going to the authorities,and civil action ,the guy gave us the money back on this car..I will tell you the only reason,and i repeat only reason he got cought was because of the crappy work done on the engine in this car.. After a week of owning this car the engine failed .so when we tore it down we found all the incorrectnes and ground off casting dates..
Old 09-25-2008, 08:36 PM
Is it wrong to let us in on who this dealer is that cheerfully refunded the money to an unhappy customer?.
