#21
A posi would slow it down.
[ QUOTE ] [ QUOTE ] Honestly Mark, I would recommend you not change the rear. Not really necessary. Car probably runs good enough for what you are doing. To go from a 3.07 non posi to a 3.55 non posi is not really worth the trouble or money. I bet you can spend that money in a better place on your car. Just my opinion. ![]() [/ QUOTE ] Mark, Sammy is right...probably not a good idea to work the motor any harder than needed. I initially thought the gears might be a good idea...but, some simpler bolt-ons like exhaust or intake would be better choices. Get it tuned up and running good...maybe add a little "sound" to your exhaust and just enjoy it. Listen to Sammy...he is older and wiser ![]() [/ QUOTE ] ![]() [/ QUOTE ] For a old guy he can give some great advice ![]()
My 5th generation Camaro came with 3.45s and I put 4.10s in that, but having a 6 speed with two overdrive gears is nice.
#24
Another point which hasn't been mentioned is what type of driving he might be doing. Not in a street vs. strip sense, but in terms of taking it out on the freeway vs. just cruising about town.
Unlike on the East Coast where speed limits are often still 55 on even major Interstates, provided when he's driving his car isn't a parking lot on the freeways, he's going to get run off the road if he's only doing 60 in CA or AZ. So, in order to keep up with traffic, I'm guessing he'd want decent RPMs around 70-75 mph, no? As the others said, based on your set up, I'd keep the gearing as is. jmho. |
#25
I've often wondered why a double OD trans is chosen when engineering a car. Seems like a 2.73-3.08 rear ratio would be best to keep drive shaft speeds down, then lowering the ratios in the transmission to get the desired gear multiplication.
My sister has a 300hp 69 Camaro. It has a 3.08 gear with a glide originally and she stepped up to 3.73. The car was a little more responsive. She never drag raced with the 3.08, but with the 3.73 the car turned a 15.01 in street form. We both drove the car and this was the best time. There really wan't much to make up in driver error. Unhappy with that time, she then chose to install a 700r4. With nothing else changed. She then drove the car 14.2@98 (pretty sure that's what the MPH was). Not only was she happy with the results at the track, it really became more drivable. The low 1st gear in the 700r4 makes acceleration fun. I don't think the shift to 2nd is too wide. I would strongly suggest considerign this trans. We took one form a 1992 Chevy van, simply slid the crossmember for the trans back and installed a shorter drive shaft. Still using the glide steering linkage on the column. Low gear is regular Drive. Great combination! [ QUOTE ] My 5th generation Camaro came with 3.45s and I put 4.10s in that, but having a 6 speed with two overdrive gears is nice. [/ QUOTE ] |
#26
I do not mean to go against the grain here. But sounds to me like you are on a budget and would like to keep your car stock in appearance. In that case I would change the gears to 3.55 or 3.73. That will give you a seat of the pants kick plus it will keep your car looking all original.
Then I would also of course have it fine tuned. Then if you are wanting a little more. Install a free flowing exhaust system.
1970 Chevelle SS LS5 - 79k original miles, Tripple Black, build sheet 1969 Camaro SS/RS X22 - 548 with 5 spd, Hugger Orange, Houdstooth Interior |
