Old 11-30-2013, 05:00 PM
PxTx's Avatar
PxTx PxTx is offline
Default Re: LS-6 camshaft
Just so I am clear on the speculation, are we talking about running slicks cause the number seems ambitious for a stock tire without a LOT of seat time and fine tuning.
Paul III
Old 11-30-2013, 08:27 PM
" has potential" on stock bias plys.
I think if this camaro has stock exhaust, it may be the bottleneck. A nice pypes 2.5" W/ "X" pipe full exhaust system will let the car breath propperly.
JJ's 69 L-89 nova did 12:20's with a 4 speed, 4:56 10 years ago. The motor was stock fully blueprinted with the correct GM cam. Nothing to fancy, just a good driver, and a good tune on it.
Pete Simpson 1962-2013 RIP
Owen Simpson
Eric Simpson
Old 12-01-2013, 01:30 AM
Chevy454 Chevy454 is offline
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: bbbentley</div><div class="ubbcode-body">I did say it was a 375hp. That is 11.0:1. It is &quot;bone&quot;stock. Non modified 840 heads,4346 Holley,stock exhaust with transverse muffler. F70x14 bias ply tires. I do have an xtra rear end that has 4.88s,but hesitant to change as it is a later date casting. 3.31 is original.Car has traction bars. </div></div>
If its &quot;bone stock&quot; then you'd be darn lucky to actually be at 11:1 compression...the 840 chambers are bigger than the 108cc listed, the domes aren't 34cc, the deck height will be off, and most folks don't run the steel shim head gaskets. When I cc'd our L72 it came in at 10.2:1, and that was after a slight surfacing of the heads...and I know a guy that tore down an original L72 and it came in at 9.8:1.
My advice, go in hoping for low 13s, that way anything better is gravy...
Old 12-02-2013, 11:51 AM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: COPO PETE</div><div class="ubbcode-body">[quote=bbbentley]I have a Federal Mogul 143 version. The price was right, but I have not installed it yet. Should I get the Crane? 375hp engine in 69 Camaro , M20,3.31 rear. Hoping for mid to low 12's. What do you think? </div></div>
depends what you have for tires and exhaust.. if its a 10:1 bone Stock engine, with small tires and manifolds.. i would bet you will make 13:40's with 3:31 gears... IMO...
Thats what i meant by &quot;bone stock&quot; usually a slapped together big block only came in at 10:1 or so from factory. 100% agreed still. Lucky to get out of the mid 13's if this is the case.
Owen Simpson
Eric Simpson
