Old 04-06-2015, 12:29 PM
Woj's Avatar
Woj Woj is offline
Default Re: Best preservation product
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Canuck</div><div class="ubbcode-body">Evaporust is available in 5 gallon pails as well, been having a field day since Christmas cleaning up parts that I might oterwise have thrown out. Clened up my driveshaft by putting it in 4 inch PVC pipe capped at one end , took only about 2 gallons of Evaporust to do the job.
For my latest restoration I am committed to either using NOS or reconditioned original parts.
Paul </div></div>
Paul,
I was considering the same method to clean up a few drive shafts, glad to now know that it works. I bought 5 gallons of metal rescue and have been using on numerous projects. It has worked wonders on bolts, steel rims and license plates. For some survivor SS rims, I bought a 30 gallon plastic trash can and put the rims in it one at a time for several hours. I also put a $10 pump from harbor freight at the bottom to keep the fluid circulating. Worked great.
Phil Woj.
Old 04-06-2015, 01:19 PM
Ryan1969Chevelle's Avatar
I would love to see some before and after pictures.
Ryan
Old 04-07-2015, 01:01 AM
m22mike's Avatar
m22mike m22mike is offline
I had a nasty looking ash tray in my 69 Malibu, inside was rusty. After a night in the Evaporust it almost looks like fresh plating, very bright.
Mike
Old 04-07-2015, 12:09 PM
cook_dw's Avatar
cook_dw cook_dw is offline
Here is the shaft I did for my 67. Using the same method of PVC pipe and evaporust. Just make sure you clean the shaft extrememly well before using the evapo. I also pulled it out after an over soaking and wiped all the black (it turns the rust into a black film) off and soaked it for another couple hours and below the the end result.
Old 04-07-2015, 12:19 PM
Did that drive shaft actually come out looking new? Wow!!
I will invest $1000.00 dollars and dip the whole car:-)
Ryan
Old 04-07-2015, 02:05 PM
cook_dw's Avatar
That is how it came out. I did nothing more than clean it and soak it. Afterward I painted the stripes back and cleared it.
Old 04-07-2015, 03:32 PM
OK I am dipping my car in this stuff!!
Ryan
Old 05-05-2015, 03:53 AM
dl7265 dl7265 is offline
Paul </div></div>
I made the mistake of shipping my driveshaft to Quanta in a 4&quot; pvc. Not cheap as you know. They returned it in a single wall carboard box that was torn. Really. When i called they said &quot; uhh FedEx broke it&quot; Okay did you make a claim or call me to make a claim ? NO.!
SO I dip mine too, as well as intermediate steering shafts ect. great stuff.
DL
1969 Buick GS Stage 1
1970 GS455 Stage 1 4-speed
Old 05-06-2015, 03:19 AM
Billohio Billohio is online now
I found this after soaking in evaporust just to clean it up a little. The product is amazing to find a finish under surface rust
Bill
Old 05-16-2015, 03:45 PM
camaromb camaromb is offline
Krown oil out of Canada is another great product for coating/rust protection. Its been used for many years in Canada for farm equipment/cars etc. It is sold in aerosol cans and also works well to knock down the light surface oxidation on metal parts.
