Old 03-04-2015, 03:46 PM
Default Re: Clutch Chatter
Good to hear Bill. Man - look at all the USEFUL help you got here. THAT is what I'm talkin' about!!!!!!!!!!! [img]<<GRAEMLIN_URL>>/[/img]
Bet you can't wait to hit the road with this bad boy, huh Bill?!!! [img]<<GRAEMLIN_URL>>/grin.gif[/img]
Old 03-04-2015, 03:50 PM
As Rick mentioned, check Pilot bearing/bushing when trans out also best check trans front bearing play too.
Does a new Pilot come w/ the kit?
Old 03-04-2015, 04:10 PM
earntaz earntaz is offline
X3
Old 03-04-2015, 05:33 PM
Rixls6 Rixls6 is offline
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: PeteLeathersac</div><div class="ubbcode-body">
~ Pete </div></div>
The car had a brand new pilot bushing, and the trans was a fresh rebuild by Crash.
Regardless, I would replace the pilot bushing again while it's opened up to get at.
Rick
69 Chevelle SS396 Silver L78 M21 Post Sedan (Berger Chev.)
69 Chevelle SS396 Black L78 4-speed 4.10 Post Sedan
Don't text and drive.
Somebody's life may depend on it!
Old 03-04-2015, 06:29 PM
Bill, get 'er going...so you can bring it out to Pavilions on Saturday [img]<<GRAEMLIN_URL>>/smile.gif[/img]
Old 03-04-2015, 07:53 PM
SS427's Avatar
SS427 SS427 is offline
An easy way to get the bushing out, insert grease behind the bushing and a little around an old input shaft on the bearing surface if you have one. Insert the shaft all the way in and using a rubber mallet, hit it a few times and the hydraulics will push the bushing right out. Works great.
Rick Nelson
Old 03-04-2015, 08:56 PM
Wax also works well. Also, make sure the pilot bushing is actually brass and not brass colored/plated steel.
Jason
Old 03-04-2015, 10:00 PM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: SuperNovaSS</div><div class="ubbcode-body">Wax also works well. Also, make sure the pilot bushing is actually brass and not brass colored/plated steel.
Jason </div></div>
Negative, Make sure it's an Oilite bushing. And do NOT grease it other than a <span style="text-decoration: underline">very</span> light coat on the input shaft. Too much grease will fill up the pores in the bushing and prevent the oil from doing it's job.
Verne [img]<<GRAEMLIN_URL>>/flag.gif[/img]
If it doesn't say Oilite on the packaging you can leave it sit on a paper towel for a while and look for a dark ring where the oil wicked out.
Old 03-04-2015, 10:31 PM
luzl78 luzl78 is offline
Verne, is it ok to use old nos Gm bushings or oillite? Do you have the part number for the oillite bushing for gm 65-72? Thanks. Jeff
Old 03-05-2015, 12:38 AM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: SS427</div><div class="ubbcode-body">An easy way to get the bushing out, insert grease behind the bushing and a little around an old input shaft on the bearing surface if you have one. Insert the shaft all the way in and using a rubber mallet, hit it a few times and the hydraulics will push the bushing right out. Works great. </div></div>
Outstanding idea, Rick, thank you very much. I do indeed have an old Muncie input shaft that I have had laying around for 30 years or more, and I finally get to put it to good use! I was planning to use it for the clutch installation anyway.
As Rick P. says, he installed a new pilot bushing when he replaced the clutch last fall, and it doesn't have 30 miles on it, so I seriously doubt that there are any issues with it.....but they are so cheap and relatively easy to replace that I think I would be foolish to NOT do so.
Thanks again for all the helpful advice here, guys.....as Sam indicates, this place rocks!!! [img]<<GRAEMLIN_URL>>/youguysrock.gif[/img]
Bill Pritchard
