Old 09-20-2015, 11:54 AM
iluv69s iluv69s is offline
Default Re: '66 ZL1 Corvette
I paíd 19k for Ramjet ZL1 motor number 34 to match my real car a few years ago..I think they listed for 23K
Old 09-20-2015, 03:07 PM
Carleen's Avatar
Carleen Carleen is offline
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: hiperf406</div><div class="ubbcode-body">The ZL1 engine alone has to be 25k I would imagine. I would love to add that to my stable but I don't have 75k, but probably worth it. My $.02.
</div></div>
New Aluminum Engine on ebay 12.900,00
http://www.ebay.com/itm/Chevrolet-All-Al...e6a&amp;vxp=mtr
Old 09-20-2015, 06:24 PM
427.060 427.060 is offline
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Carleen</div><div class="ubbcode-body"><div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: hiperf406</div><div class="ubbcode-body">The ZL1 engine alone has to be 25k I would imagine. I would love to add that to my stable but I don't have 75k, but probably worth it. My $.02.
</div></div>
http://www.ebay.com/itm/Chevrolet-All-Al...e6a&amp;vxp=mtr </div></div>
That is not a GM built engine.
James
1968 Beaumont SD396
Old 09-20-2015, 08:03 PM
Carleen's Avatar
Why do you think this 66 Corvette has a GM-built engine?
Old 09-21-2015, 01:12 PM
----Well,,,I would guess that's because the add gives the part# of the GM ZL1......Bill S
Old 09-21-2015, 01:42 PM
Carleen's Avatar
1966 Corvette Stingray Convertible
NEW 427 GM ZL-1 aluminum big block (part # 3946053) w/ new GM aluminum rectangular port heads, part # 12363401,
The newly ZL1 blocks 12370850 have Casting # 3946053
Old 09-21-2015, 02:34 PM
TimG TimG is offline
Bill, in 1967, only the solid lifter cars had 80 LB oil pressure gauges. I'm pretty sure that held true in 1966, also.
Old 09-22-2015, 01:09 AM
GTO_DON GTO_DON is offline
My 67 only has a 60lb gauge and it appears to be the original cluster.
1969 GTO convert RAM AIR 4spd
1964 GTO convert survivor
Old 09-22-2015, 02:29 AM
Guest
Posts: n/a
</div></div>
http://www.ebay.com/itm/Chevrolet-All-Al...e6a&amp;vxp=mtr </div></div> Not the same as GM ZL1
Old 09-22-2015, 01:55 PM
Nasblu's Avatar
Nasblu Nasblu is offline
1966 L36 427-390 corvettes did not have a 6000 rpm redline only L79 cars had this tach in 1966.The 66 427-390 cars shared the 5500rpm redline tachs with the 327-300hp cars. It wasnt until 1967 that the L36 427-390 corvette motors shared the 6000rpm redline with the L79 327-350hp and L68 427-400hp motors. So according to the 6000 rpm tach in this car it would have been an L79 car. But it would have had a 60lb oil pressure gauge so I am assuming that the 80lb oil pressure gauge was added to this cluster at one time. Although not typical,80lb oil gauges have been found on 66 documented original L36 corvettes, but in most cases 60lb gauges were used.
